New add-ons
How would I go about adding the mirrors with the light under them in my 2014 Silverado  ?
Also what about OEM the trailering brake ?
Last question ...
Is it possible to install the OEM fog lights ?
It can all be done. Not easily or cheaply. You want the DL3 mirrors, there is a thread about the mod in the Mods & Accessories section of this forum. OEM fogs should be a popular mod and there should be some info on it if you search. Trailer brake may be a pain, might be easier to go aftermarket. There will be lots of wiring involved, new door harnesses and maybe some pinning of your BCM connector to make the DL3 mirrors have the signal, heat, auto dim, power-fold and puddle lights to work.  My advice, grab a large coffee before skimming the 60 pages of info. If you need retro fit harnesses, make a shout out to Pgamboa here on the forum, he makes and sells these harnesses I believe.
It's always easier to get the truck with the equipment package that you want, rather than try to add stuff on down the road. However I know your pain as GM likes to put all the nice goodies on the LTZ/SLT so you are handcuffed into getting a bunch of stuff you don't want for the few things you do want. Modern day capitalism at is finest.
I believe the OEM "integrated trailer brake controller" cannot be added if it wasn't equipped. You will need to plug in an aftermarket one.
⬆️ What he said. You can’t add the factory controller. Many have tried all have failed.
There’s one in the parts catalog takes like 30 minutes to install
https://www.gmpartsnow.com/oem-parts/gm-trailering-brake-controller-pkg-19330154/?c=Zz10cmFpbGVyaW5nJnM9aGl0Y2gmYT1jaGV2cm9sZXQmbz1zaWx2ZXJhZG8tMTUwMCZ5PTIwMTUmdD1sdCZlPTUtM2wtdjgtZmxleA%3D%3D
If you want a aftermarket on the dash like the integrated here is a thread with some different ones
thread with some ideas for you on location and controller options.
6 hours ago, aczr2k said:
I have a set of takeoff DL3 mirrors for sale.  I want them out of my shop.
How much?
18 minutes ago, aczr2k said:
How does $275 plus shipping sound?
I have pics I cans send.
My fault, I thought DL3’s were the bigger tow mirrors.
