Factory aluminum 17 spare
.. you are not alone.. not from my truck but this was the 17" spare from a 2018 GMC Sierra Elevation with OEM 20's
12 hours ago, Thfsierra said:
Gm did put aluminum spares in some of these trucks. My 16 Sierra has a 7 spoke black painted aluminum wheel.
THATS IT!!!!!!!!
Thanks guys you have been a huge help and I am sorry I pushed someone’s bullshit meter to the breaking point
S### happens.....
Definitely never saw that wheel before. I had to put the spare on my 15 over the weekend. It's definitely a steelie. This is the wheel that I've seen most commonly. I had an 06 Titan before this truck, and the spare was actually a matching alloy wheel.
My GMC 2500 15i is a steel wheel 17" I have 18" chrome rims on mine.
Sierra Boy
Pretty sure it depends on the trim level (or at least in later years...)
'18 LTZ Z71 and I have the aluminum as well - it was standard offering for all LTZ Z71's that I had seen when I was shopping.
This is just entirely baffling to me. I never would have guessed they'd ever spend the money to machine an Aluminum spare wheel.
I see now that they've done it, but why? It's a spare. Who cares what it looks like, you use it until you can get a fix.
Sent from my SAMSUNG-SM-J727A using Tapatalk
My '08 Caddy CTS had an aluminum spare wheel with a temp tire on it??? Who knows why, maybe it's a weight thing.  Now I'll have to look under my 18 when I get home to see which wheel I have.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
