It's a 6.2 .. .If I recall I was towing a small trailer at the time.
Read this:
http://gmauthority.com/blog/gm/general-motors-technology/gm-aerodynamics-technology/gm-active-aero-shutters-technology/
May be this is the reason. Look at your PRO codes and see if you have VTI in there.
I think you should be OK. It won't hurt if you check with the dealer too.
Yeah, wonder if you have the shutters. Mine doesn’t and my temp sure as hell doesn’t do that.
Just now, UGADawgs said:
My build sheet shows I have them:
Then how does your temp gage dance?
Doesn't. Starts cold (65-80), goes up to 210 pretty fast, within a couple minutes, and then stays there.
I checked mine. I don't have code VTI. Mine takes forever to reach 180. It sounds like VTI is for mainly 6.2L and some 5.3L Z71 packages.
In southern California I prefer not to have it ?
I think we tried to pattern what trucks got them in a thread a few months ago and I never made any sense out of it. My 6.2 doesn’t have them. Thought it was because of NHT but then someone else with a non-NHT 6.2 also didn’t have them but another did. I’m fine without because it’s just another thing to malfunction.
Mine stays around 200 unless I'm towing. When towing 7000lbs, it fluctuates as shown above. It goes to about 220, then drops to about 200. That pattern continues the entire time I'm towing. I have the 6.2 with 10 speed.
Sent from my SM-G892A using Tapatalk
I checked mine and it stays at the line before 210,  so I am guessing that is around 200 or so.  It is a 6.2 and I have the shutters.
On 5/5/2019 at 11:14 AM, AMPRG said:
Read this:
I just got my build sheet from the "[email protected]" folks. Very friendly!
I have VTI on my 5.3L DFM RST. Didn't realize that!
You can also scan the QR code on the door (driver side). It will list the RPO codes along with the VIN.
Thanks! Didn't realize that. I tried scanning it with my iPhone, but it didn't read it.
My truck has 2 QR codes. The big one is the VIN only, and the small one includes VIN and RPO codes. I had to install a 3rd party free app on my Samsung phone to be able to read the codes.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,180 Guests (See full list)
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
