We didn’t get a ton of snow, maybe 6-8”. But it’s blowing around everywhere at 35 mph++ so most surfaces either only have a dusting, OR 2 foot drifts. Not much in between. 😆
The snow we did get also happened to lay down on a nice layer of ice and freezing rain so the cleanup is taking awhile. 20 degrees and wind chills in single digits don’t help.
Worst part is definitely the shock to the system since last Monday it was 72* and me and my son had a nice drive down to the creek in T shirts and shorts.
Probably 8-10in where I am, lots of blowing snow. South and east of me got 12-20in easy in places. I drove through Durand, WI this morning for work and they had at least 15-20in there as well.
Tonights low is below zero again and then we'll see low 50's by the weekend lol.
We have one more cold day and a bit more lake effect tonight. It's 18F right now with a windchill of -10F. Wind has died a bit after the sun when down. That was some real wet snow. My back is trashed. LOL
Going to get down to 5F tonight with tomorrows high as around what it is right now. May break freezing Wednesday.
Two nights right at 32*. The Thursday 92, Sunday 99
  • Haha 1
We're getting the tail of the storm here that totaled just over 46 inches of rain in Maui over a few days last week. We've got flood watches in effect. This is also unusual for this time of year as winter turns to spring. I mean, it's often rainy, but this is a LOT of rain. The rain is also how we turn this place into mecca between mid-April and October.
Winter got its final shots in on my wallet over the last week. Last Tuesday it was kind enough to hail and punch holes in the roof panels of my gazebo. Then this Tuesday the cold snap finally did my original 2018 battery in. No warning, no fade to failing, just woke up today and she was gone. Charger wouldn't even touch it. Tested at just under 12v and all of 22 CCA, lol! Went to Wally and got an Everstart AGM for $170. Not too bad. But I am done with winter now.
Local news tells me today that while this year has been twice as snowy it is still 1-1/2" below seasonal average. It was pretty light last year.
Talked to someone yesterday who has had a mountain cabin for years. Usually 4-6 feet of snow there, no snow now.
Very dry, scary for fires.
I used to go up to St. Mary's Glacier when I was younger and it was awesome. Right up to the road. Last time I was there, it wasn't much of anything.
78 degrees today. Brick house gets pretty hot in the sun and holds it forever so we kicked the air on. If nothing else to make sure the 1997 vintage unit still works. Unfortunately no fan but just needs a cap which I ordered on Amazon. It’ll arrive just in time for it to drop back into the 30s. Least I won’t sweat installing it! 🙄
  • Haha 1
Roughly seven inches of rain in the last say 60 hours or so and now back in the 40's. We are supposed to have a few days of clear then another four day rain wave. It's a bit more than spring showers. Pretty sure we are no longer in drought mode. Standing water in fields. Rivers out of bank. My sump system is running.....allot.
We got a few inches Wednesday, need moisture bad. Worst dry spell in 10 years here.
We had a brief shower by Texas slang resulting in about an inch. Along with a front that brought a bit of a breeze up to 35 MPH. And a slight drop in temperature from 80 to 50 degrees as the front leaves. A normal week by Texas standards.
Another whacky weather week up here. Tornado warnings in 4 of the last 5 days. Phone alert at 1:38 AM for the first one took a few years off my life. The others have been in the late evenings. Thankfully no damage. Just lots of rain. We had already exceeded the monthly average in the first 7 days. Not sure where we stand now but has to be a record.
I’m sure @Grumpy Bear has been seeing similar crap down by him. Tonight’s band was 1000 miles wide…
    • The part # is 84520447, mine does not have the cooled seats but I'm willing to possibly change the cover and foam if needed.   I tried that site and a few others,  added to cart and then paid. About an hout later I received a refund stating it has been discontinued.
    • Thought I would add to what Bruce answered, not only do the HD models use the torsion bar system, there are I believe 5 different torsion bar spring ratings that are all physically interchangeable with all the HD trucks going from a two wheel drive 2500 all the way up to the duramax or a gas engine truck with a snow plow prep package front end weight capacity that use the maximum sized torsion bar. It starts from a 4400 lb rated set in 400 lb increments up to 6000 lb. If one wants to fine tune the ride for a certain truck application they can swap out the torsion bars.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
