Well spring took a hiatus. 34 degrees this morning, 1 inch of snow and fog. The last few mornings have been in the 30's. The moisture is nice.
Fog and wet. Yes it’s fantastic. No snow accumulation. 30 F but ground too warm. Anything to lower fire hazard welcome. 4 of my Aspen transplants thriving.
We just missed 90F and the humidity was off the hook for the first time this year. Storms in waves. Mowing every two to three days. Rabbits loving my garden.   :
Edited by Grumpy Bear
  • Haha 1
6 minutes ago, Grumpy Bear said:
We just missed 90F and the humidity was off the hook for the first time this year. Storms in waves. Mowing every tow to three days. Rabbits loving my garden.   :
Oh how I miss Indiana and Illinois.....NOT.
  • Haha 1
  • 2 months later...
We have been getting rain regularly. 👍
  • Thanks 1
Mild drought in my neck of the woods. With the abundance of 100 degree days. Close to normal here. The trade off is 6 months of pleasant weather. Watering consists of flowers, small trees about twice a week. The grass just quits growing but comes back with rain. If I see a patch thinning I water just enough. I get a chuckle out of people who spend a fortune watering. Of course living in some areas they’ll fine you for browning grass. Love those HOAs.
We too. Talked to my insurance company yesterday in COS and they haven't gotten a drop of the monsoonal rains we have for almost 2 weeks. Washed away our roads one afternoon. Raging rivers from spring flows off the mountains around me.
We were getting rain every day for three weeks straight to an average of 3 to 4 inches by weeks end.  But have not gotten much in the past two weeks.  Storms all around us but seem to fizzle out by the time they get over our house.  This house we bought has a sprinkler system that has it's own well.  From what I was told it is only 40 feet down.  Water table here is high.  So the cost is to run the pump three days a week for about an hour.  I adjusted all the sprinkler heads to stay off things but the wind moves some and now my one area of white lattice is brown from the iron in the water.  Going to try some of the iron remover that you use on vehicles to see if that will take it off.  I did use Iron out but you have to work that in with a sponge.  I'm more on the lazy side and if I can just spray and it comes off, it's a better option to me. :)
Storm last knight, 45 degrees this morning. I usually sleep with a bedroom window open a little, got up and closed it last night.
  • Thanks 1
Rocky Mountain AC is really low cost and effective....☃️
5-1/2" of rain here in the last two days. 4-1/4" of it in the early hours this morning.
100 miles north it's brown grass and dirt.
Rain on and off yesterday and last night. 46 degrees this morning and the heat came on. I have a temperature sensor in the garage, it was 45.
More rain than anyone has seen since 2018. That was the year of the Spring fire that wiped this area into a smudge.  The sideways rain at 50 MPH has found leaks in my metal roof that are exasperating. Even doors are leaking.....part of the fun of living in the mountains at 9000'.   The residence time of water on a roof more important than anything else because no roof is waterproof in a microburst or the 112 MPH winds we suffered last year. Getting anyone to come up here to help me is tough. Roofers and contractors say they will be here then never show when they see where.....LOL
There’s a cool front predicted to come through tomorrow bringing much needed rain. And a drop in temps. All the way down to 90. A welcome relief, even ifs for a couple of days. Today it supposed to reach 104.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
