Does GM warranty chrome wheels?
Bought my 2018 last August with 3,200 miles on it(loaner truck- titled new). It now has ~13,000 miles on it and my chrome wheels have some light pitting and chrome flaking off.
Just curious because less than a year of ownership and only 10k put on by me and the wheels are already starting to look not good.
  • Replies 34
Until earlier this year they would almost certainly cover them. GM started a new program where the dealership takes a picture and sends to GM and they decide. Dealer has no say. If they are acually peeling you are probably ok though. If it's a "no", don't hate on the dealer.
Too much abuse. I would tend to agree with GM on that. GM paid for a LOT of repairs that should never have been warranty. Driver scuffs curb, screwdriver in pocket pokes hole in seat, driver clips garage door with mirror, etc. Oh, geez, he's a good customer or he's a buddy of the owner or the service manager. Lets take care of that under warranty. Seen it many times.
Possible winter salt damage?  Conspiracy theory here, Michigan is one of the largest salt mining states in the country, they ship salt to all of the upper mid-western and north-eastern states. So what's good for the Michigan salt miners is good for Detroit by speeding up the vehicle replacement cycle. There are alternatives to salting winter roads, I used to live in eastern Wa. state where they never used salt or brine on winter roads, sand and in later years they've used the corn based squirrel pee stuff.
His peeling wheels on a new truck...is bad press for GM and will further depress sales.
If you were thinking of buying a new GM, saw his crappy wheels and found out he owned the truck for less than a year...would you buy one?
We had a MILD winter. His wheels have not seen hardly any salt. My steel wheels are not even rusty and they went thru 3 winters of salt.
I do live in Illinois and Illinois does like to salt. The truck did get run through the car wash when I could. But I set out to give er a good hand wash yesterday and started working on the wheels and was pretty surprised to find chrome flaking off in spots. As for the slight pitting, I’m not sure if some chrome polish and a Mother’s ball will do the job or not.
I could understand if I had the truck for 2-3 years or if I had 50k+ miles(brake dust).
  • 3 weeks later...
Good to know. My father in law is experiencing this on his 2016 Denali with chrome 22" wheels. I will let him know about this program...
Thanks!
you need to upload pics. GM uses PVD or powder coated chrome now, GM calls it "painted chrome" they don't use the old dipped copper & chrome plating process. I seriously doubt it is peeling, but yes paint does pit. the PVD chrome is extremely resilient to salt corrosion.
You might have aftermarket remake's that are plated chrome.
I’ll take pics when I get a chance to clean them up more. It’s been so damned hot here that I haven’t had the motivation to do it. It may just be stubborn brake dust.
I’d hate to think that someone swapped my wheels for afternarket at a dealership.
  • 2 months later...
Finally getting around to this. These are all off of one wheel.
I have an 18 as well with the same wheels. I have no issues with the chrome. That should be covered under bumper to bumper
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 647 Guests (See full list)
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
