15 minutes ago, sdelam said:
Good info, Thanks. The trailer calibration thing is a pain right now. I have the camera mounted on the roof of the toy hauler angled down at the max limit per the instructions due to the size on the ramp door. Less of an angle would leave larger blind spot directly behind trailer.
Transparent trailer won't calibrate will the camera in that location.  The trailer camera needs to be in center of trailer 4 inches higher from the ground than the camera in your tailgate with trailer attached.  The camera needs to be at an angle of 35 degrees.  Point the camera directly down to the ground and tilt it up to 35 degrees.
I realize with toy haulers and trailers with drop gates this creates a problem.  You could potentially smash the camera on the ground.  You may not be able to use transparent trailer with these trailers.
#iworkforGM
#iworkforGM
Did not see that in the instructions that came with the camera or the owners owner's manual. That would be good info to have before I drilled holes in my camper. I did consider placing it in the center of the door, there probably is enough ground clearance for the camera but the instruction specifically say not to route the cable under the camper.
It did calibrate eventually, just took about a mile of less than 30 mph. But lost the cal during fuel stops. I thought perhaps it was due to me not allowing the system to fully boot up before pulling away from the pump.
Edited by sdelam
17 minutes ago, MTU Alum said:
I would say no.  Rpos with trailer cams are:  UVI and UVS.
#iworkforGM
Only reason I ask is because it appears that the camera coax cable is actually taped under the bumper, at least on my truck. I ordered the trailer receptacle with the camera ports and that cable plugged right in. Nothing appeared on the infotainment, as expected but I haven’t tried plugging the camera in yet since it’s so expensive... maybe the dealer has to program something?
I haven't seen an owner's manual yet.  Some of problem maybe due to the 2020 cameras not available yet and most people are using 2019.  With transparent trailer being new for 2020, there probably new instructions for transparent applications.
20 minutes ago, 2k19Sierra said:
I'm not sure.  I know you must have a trailer information module.  This shows up as the trailer app on your infotainment screen.  Option code U1D.
Yea exactly. I might have the dealer have a look at it next week when I get my first oil change. See if they can program/activate something to make it work. Been scouring the wiring diagrams to see what i could be missing. I even have the trailer camera module fuse installed! Can’t be difficult to get camera to work.  Maybe I need one of these video modules installed...?
Good point, I did use a 19 camera.
I have been watching all the camera issues everyone is having. I came across a HD coax cable at Amazon. Here is  the link. This one is 50 feet. I am wondering if this would help a lot of people IF this would work. I know it has the power cable with it but that wouldn't be needed but the HD and made for security cameras. Maybe someone would chime in and take a chance on a 2020 camera utilizing this cable?
SyncArrow Premium PRO-Grade 1080P HD Premade 2-In-1 Multi-Purpose Fire-Rated Double Shielded BNC Video Power Extension Cord CCTV Combo Coaxial Cable with BNC RCA (PRO-15M2W, 50 feet, White)
Chuck
Edited by Gecko50
I am looking at buying a 2020 Silverado 2500 HD LT. It has the convenience package 1&2 that has Advanced Trailering Package. When in reverse it only shows two camera angles and three icons on the screen. The hitch and regular back and with or without lines.
Before I buy it I wanted to see if it included the feature for the transparent trailering.
The hookup in the rear just has the 7 way and 4 way plug. Not the one for the camera port.
So confused. Can anyone help. Not sure if the wiring is there and/or how the icons appear on the screen.
It does not have the system.  You need the 360 camera (option uvs) for transparent trailer.   You probably need at least ltz trim.
#iworkforGM
yes, that is correct. LTZ or High Country for the transparent trailer view . You need the technology package and i believe the power folding/extending mirrors with the side view cameras.
U1D     Advanced Trailering System,
includes checklist, trailer maintenance reminders, trailer security alerts, trailer mileage, tow/haul reminder, trailer electrical diagnostics and Trailer Tire Pressure Monitor System module
1 - Included and only available with (PCM) Convenience Package II or (ZL6) Advanced Trailering Package.--   --   A1
Thanks. You guys are awesome. The dealers did not have a clue.
Where are you guys pulling the details of stuff like that from. I hate to bother someone for simple questions I can find myself.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
