Have a 2020 1500 RST. Stock suspension. Looking at putting a 3.5” - 4” kit on the truck.. want to run an aggressive looking 35” tire on stock 20” wheels but don’t want serious rub.. anyone running a similar setup? Any pictures out there?
I installed these awhile ago but this is my 5.3 Elevation. It is levelled (in the rear). 20x9 Fuel Rebels on 33" Kendas.
Edited by diambo4life
Here is my setup
Fuel Vapor 20x10 -19mm offset
Nitto Ridge Grapplers in 275/65/20
I put on ready-lift 2inch leveling kit
did a mudflap bracket delete with trimming the innermost portion of the flap and zip tied the liner in one spot.
No rub at all
Used this forum to pick out my specific wheel and tire set up so I’m returning the favor!
20” Vossen HF6-4s 20x9.5- +15 offset.
275/60R20 Falken Wildpeak AT3W.
it has a 3” Superlift lift kit. The tire size is same as stock on the stock 20” OEM wheels. There is zero rubbing at full turn. This setup gives a similar look to a leveled AT4.
Edited by Trevor Towers
Adjust wheel specifications listed erroneously.
20” Vossen HF6-4s 20x9 - 0 offset.
Looks great! Do you happen to have a photo down the side showing how much poke there is?
I do. It should be somewhere around 1” of poke over factory. Also added a picture of the clearance at full lock. I wasn’t interested in going any bigger than the stock tire sizing because I didn’t want to impact fuel economy too much with weight, overall I believe the new setup is just a touch lighter.
Thanks, that looks good. I actually had ordered these wheels a few days ago but in a +15 offset and 9.5” wide. Didn’t realize they had the other offset and widths available.
Vossen has a custom sizing program, you can get them in configurations from 8.5” - 12” wide and offsets from 0 - +48mm. But I just double checked my receipt, it says 20x9.5in +15mm offset. I called the sales person to confirm because he was telling me 0 offset over the phone previously, I think he was just mistaken. He said that the 20x9.5 +15 is the STANDARD size for these. I’ll update my post. What kind of tires are you going to fit on your vehicle?
Here are some more pictures for you as well. I included an image of my city MPG in just normal driving to show I can still maintain essentially the same MPG I was getting before. All city driving.
Oh nice, thanks! I have some Toyo open country at3 275/60r20 im going to put on them.
Here is mine.
2020 Silverado LTZ Z71 4WD
Bilstein 6112's in front, 2" level
Bilstein 5160's rear with 1" block
Fuel Sledge 20x9, +19mm, ceramic coated
Toyo A/T III, 285/60/20
No rub. Tires stick out past fender by about 5/8". Very happy how it came out.
    smandy
    smandy
  • Who's Online   1 Member, 0 Anonymous, 466 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
