On 1/24/2022 at 8:28 AM, ThatredneckguyJamie said:
Did you have to use spacers to retain your factory wheels? Their website mentions  5.75 backspacing
Sorry I'm just seeing this, no spacers used
On 2/12/2022 at 4:25 PM, USCGRetiredJosh said:
2020 AT4
20X9 Replica Satin Black Snowflake
BFGoodrich KO2's 275/60/20
I like this look, considering the same wheels for my silverado. do you have any other photos? Are these the +24 offset wheels?
On 1/19/2022 at 10:21 PM, Low Elevation said:
Looks great. What kit did you use to lower it?
Thanks buddy, I used the beltech 4/6 kit. I had a shop do the work as im not able to at this point.
On 2/26/2022 at 8:05 AM, WanderingSpleen said:
Put some 295/70/18 Toyo Open Country AT3's on the pig this morning.
All stock stuff on a trail boss; no rubbing.
Looks great! Major visual improvement
275/60/20 cooper rugged trek, 20”x9” 24mm offset satin black snowflake replicas. Coopers are way quieter (and cheaper) than the dura tracks on my wife’s trail boss, and just as if not more aggressive tread, really liking this set up so far.
Has anyone found a way to calculate the largest tire/wheel setup without rubbing? Currently have Nitto Ridge Grapplers 35x12/5r22s w/ 4" BDS lift and even after 25,000 miles I'm still suffering from rubbing. I want to replace the tires in the next 4-6 months but have heard there's some magic formula to deciding the biggest tire without the rub. Thanks in advance!
Have you done any trimming or removed the bracket behind the fenderwell?
Yea removing the mud flaps and the bracket behind the fenderwell the u can push it back far enough to clear most close calls.
I haven’t. All stock
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
