2019 Silverado RST 5.3L. General grabber A/Tx 275/70r18. Full throttle +0 offset. 6mm spacers in front. Stock suspension.  Slight rub and full lock turning left in reverse.
On 9/8/2021 at 6:39 PM, Freeagnt54 said:
Icon Compression 17”x8.5” 0 offset
Toyo open country at3 275/75r17 (34”x11.5”)
Stock height? Any rubbing or trimming?
For those running Nittos, how does the actual mounted inflated height compare to the advertised inflated height?
275/70/18 bridgestone revo at3
3.0 RST duramax with 3.5" RC lift/ level
Stock 18" rims
Edited by SC4R3C120W
Picked these up on FB Marketplace brand new with center caps still in bags for $775 shipped. I love them over the stock silver 18’s
Part:84641199
Toyo AT3’s 265/65/18
Bilstein 5100 1” lift in front.
Edited by Mike Borowski
Stock 18" rims
Nice.  Hope you got new upper control arms for it.  We got a 2020 gas GMC Elevation here that has a 2 inch level.  Stock UCA ball joint failed, and hard.  Took out the CV, the wheel, ABS sensor too.
Correct.... New upper control arms and mine being a diesel, they recommend the strut spacer instead of the coil overs because of the heavier engine. Plus the 2.5" block with new V2 shocks. Rides just the same as factory. Was surprised the tires didn't ride more stiff or make any road noise. I was looking at 34's, but since I commute 120 miles a day, i wanted something lighter weight to try and keep mileage. These Bridgestone's were one of the lightest 33's while still having a little all-terrain patterned tread/look. They are each 15lbs heavier then my stock 265/65/18 Michelin LTX's, adding 60lbs more or rotating mass. I also got the RC speedometer calibrator to keep DIC correct
2020 Sierra AT4, 5.3L
275/60R20 Mickey Thompson Baja Boss AT
20x9 Fuel Rogue +1 offset, Gloss Black w/ Machined DDT face
1.75” ReadyLIFT Leveling Kit with UCAs
27 minutes ago, bluemonstercali said:
Truck looks amazing!!!! What tire size?
The wheels are Vossen HF 6-4 20x9.5 @ +15 offset. The tires are Falken Wildpeaks AT3W 275/60 R20s. No rub at stock height. This setup was on my old truck (21 Elevation). I just swapped them out!
On 3/28/2022 at 9:28 PM, Mattuz93 said:
3.5” Rough Country lift
295/65/20 ridge grapplers
Truck looks great great, very similar setup to what I would like to do. Did you have to run any spacers or make any mods to eliminate rubbing?
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 870 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
