The only issue I have been having is every once in a while my touch screen will freeze. Then when I shut the truck off for 20mins it return to normal. 2019 Trail Boss
Sent from my SM-G973U using Tapatalk
Still haven't got the update. Does anyone know if the dealer can manually do it? It's not a rush really, just seems like it's been out for some time and I would have thought everyone would have it by now.
Also didn't know since I had my system upgraded to NAV (didn't come with it) if that might have jacked up the updating.
Does the truck have internet?
Might need to make a hotspot with phone?
I could be way off
I could be way off
It can connect to my home wifi when I'm in the driveway and my phone. I can run the check for updates from the menu and it will say No updates or something like that with the current date/time so I assume it's able to get out and check.
But thank you for the suggestion
Thanks for the replies, but can someone please assist with my SD Card problem?
Anyone know how to resolve?
Really awful an over the air software update may now necessitate need for a dealer visit.
I hate going to the dealer; them damaging my vehicle; the time and hassle involved; etc.
Would love to be able to fix myself.
Please do advise, as I need nav.
Argh. :(
Edited by dbs600
On 10/31/2019 at 6:20 AM, Milleam said:
Thats strange, this is what mine looks likeIMG_2060.thumb.jpg.c6676becab04d436bd0c2d974af09c95.jpg
You have the low end model like me, it is the IOR (not the nice IOS model like they have).  This model is NOT updatable despite it having the option.   We are stuck with this 2014 crapper model.
Edited by Ktoonsez
Weird I have the same on an RST. Is it a month in the build kind of thing or just that it’s not the premium model?
Mine is also an RST but it's just how it was ordered when the dealer did the build sheet.
1.  They can order the basic IOR model made for the LS level vehicles back in 2014
2.  Te IOS model that comes with HD radio, over-the-air upgrades, ability to add apps, climate control app and SD slot for Nav upgradability
3.  Or the mama-jama IOT that has everything from above plus Nav.
Edited by Ktoonsez
I just purchased a 2016 Canyon, i don't find an option to even check for an update, it is an SLT with Nav and the 8" screen. OnStar had an issue enabling their software, I may run by the dealer on Monday to see if my system has a problem.
I found this some very good information
https://www.corvetteforum.com/forums/c7-tech-performance/3759311-hmi-2-5-2-0-1-1-1-0-specifications-and-radio-firmware-versions.html#post1591200351
Edited by oldman_58
interesting. I don't have any issues with mine, but I think my 16 was better AND had HD radio. Must have been the IOS.
Count yourself lucky ?.  Mine crashes and reboots at least 6 times a week (sometimes all the buttons in the center stop working too because its all tied in together and dont work till the vehicle is turned off for 20 minutes).   Took it to the dealer and they were useless, all the did was reflash it to the same exact 2014 firmware it already had.
Can anyone confirm they got the update without having a subscription to OnStar/Connected Services?
Yes I can.  I just used my own home wifi to download it.  ?
Thanks. I was hearing you can download it through wifi but thought maybe you won't have access to it at all if you don't have a subscription.
Sorry to bother, but the problem persists.
I’ve tried removing the card, cleaning its contacts, etc., but to no avail.
In the rare instance that it works, it only does so intermittently, as it won't upon a subsequent start up.
Why did an over the air update have to ruin our systems? Anyone able to fix / resolve?
Don’t want to take the truck to the dealer, be without alternate transportation and have the dealer either scratch, dent or otherwise damage or steal something.
Upsetting failure on GM’s part to push out defective software. Really upsetting.
Please advise if anyone has any GM contacts I can discuss this with for proper, prompt resolution.
I Imagine another update needs to be pushed out to the truck get it working again.
In the rare instance it works, but only intermittently, as upon a subsequent start up it won’t.
Why did an over the air update have to ruin our systems!? What gives!?
Really don’t want to take the truck to the dealer, be without alternate transport, and have the dealer likely either scratch, dent or otherwise damage or steal something out of or off the truck.
Such an upsetting failure on GM’s part to push defective software out.
Was. Not. A. Problem. Before. The. Update. Really, really, really pissed now.
Please advise, and if anyone has any contacts at GM I can discuss this with for proper, prompt resolution.
I Imagine they need to push another update out to get it working again.
Do they even know this is a problem?
Here's my post:
Edited by dbs600
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
