Lift suggestions
I thought I was settled on a lift but rethinking it now.  I'm looking for 3-4" lift that rides best on the road, can handle a loaded down bed and works for light off road use.  I hit some forest trails and use it on the beach when on vacation.  The truck spends most time as a daily driver with weekend trail duty or loaded down for summer trips to the beach.
What are the best options for ride quality?  I was thinking the Icon coilovers stage two but would still need blocks or something for the rear to get any lift out of the rear.  From what I understand the coilovers take care of the lift up front.
Are there other better options and if not what do I need to add to the Icon kit to get the lift in the rear to match what I lift in the front?
I'd really like to hear from anyone who did a lift and can comment about the ride quality.  Currently I have the LTZ Z71 with the Rancho shocks and the ride is horrible in all driving conditions.
Thanks
If your gonna lift it, just go 6”. You’ll be sorry you didn’t after doing a 4”. Depending on your budget, there is quite a few options. If you have the coin, go with King Coilovers and shocks.
CST 4.5” Lift, it’s the perfect height, absolutely love mine!
Doesn’t widen the track width or turning radius and allow you to keep your stock wheels if you like them.
Coil Overs give the best ride quality overall. I’m using my truck as a daily driver much more now, perfect height for everything especially being able to get into and out of garage parking lots and much easier to get into and out with the 4.5”. I’m running 295/60/20 Nitto Ridge Grapplers on a 20x9 +1 offset Fuel wheel. CST Kit came with 3” rear blocks and I added an “add a leaf” so it won’t squat when hauling a few hundred pounds.
Front CST Coil Overs with rear CST rear Piggy Backs.
Out Hog Hunting
Out Hog Hunting
That looks like exactly what I want.  Is there a kit number for the coilovers or part numbers for the blocks and leaf you used?  Did you do it yourself or have a shop do it?  Thanks
Had a shop do it, took a couple days. It’s much more versatile than the 6” and the Kit itself is superior quality, hand crafted in the (California) USA. The stage one kit doesn’t come with front shocks or rears, I wanted something specific to the height and went with the same manufacturer. Heard great reviews on the kit from a few others in the forum and I’m so glad I did.
Here’s the cheapest I could find the kit for ($1600)
https://performancelifts.com/cst-2014-2018-gm-1500-4-5-stage-1-lift-csk-c3-19-1.html
Cst Coil Overs are approximately $1500 CST you’ll definitely want adjustable for the front, that’s my only gripe, wish I could adjust them.
On the rear shocks, starting around $130, you can go with anyone, CST, King or Fox. Fox shocks are more readily on the shelf versus custom built CST or King which could take a while for replacements. Fox are usually in stock or a day away.
Oh, forgot to mention that with the CST lift they don’t have to cut your front differential at all unlike the others.
Thanks.  I checked their site and they don't have that kit out yet for the 2019+.
I've read a lot on the Fabtech and Dirt Logic lifts.  Anyone running that with info?
i just ordered the bds 4" lift for my 2017 an the moto metal mo970 rims gloss black w 33x12.5 nitto ridge grapplers. install on tues.. ill post pics after.
Sorry. Procomp makes one, I’d hold off another year, avoid Fabtech. CST should have more coming out very soon, I wouldn’t rush into it. Call around tomorrow morning, 4wheelparts is who did mine and may recommend some but I’d even contact CST and just ask them what’s available or coming soon. Good luck!
I’ve got the 3” Rough Country kit on my High Country, I’m very happy with the ride, the front rides exactly the same but the rear is much better. I’m sure it’s because the shocks were replaced with e the RC  shocks and it made a very noticeable difference. Sorry, no pictures yet, I’m going to try to get some this weekend.
I’d keep an eye on your front end geometry with that kit, it’s a stretched level. I’ve heard far to many horror stories on RC kits and the serious and expensive repairs that came with RC just for a look.
I've been super happy with my ReadyLift 4" lift. No issues with angles and only slight rubbing at full lock in reverse with 35s on 17s. Rides really smooth and even though I prefer a stiffer suspension on a lifted truck, I have 0 complaints. Install was pretty cake too.
What shocks did you go with?  I assume the shocks were just stock length since the lift appears to use spacers and blocks with new UCA"s?  Thanks
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
