'19 3500 L5P (black/black)  Over 100 today and AC isn't working.  My guess is the climate control computer got really hot and that caused it.  Was in direct sun for about 3 hours.  After leaving in shade at home, it's now working.  Pretty lame.  Anyone have this issue? Is there a fix?  Hate to waste a day at the dealer just to be told is a-okay.  (Compressor clutch wasn't engaging, by the way.  Ice cold now that it's working again). Thanks.
I'm in hot humid Louisiana and must say my a/c works great and haven't had a problem all summer.  100° temps with 115° heat index and blows 38° out the vents.  Hope your a/c isn't on the brink of going out like another members here did.  The whole interior, dash, seats had to come out to change a leaking evaporator.  Not a pretty sight...
Here's (from a member Bill) what an interior of a '19 looks like when changing an evaporator...
Edited by mafd2
6 minutes ago, deminimis said:
Ugggh.
Yep... I never followed up with him to see how the outcome was.
I imagine it's a computer board that just can't handle the heat.  Worked fine once I parked in the shade after a couple hours.  Works fine this AM as well.  My guess is they won't be able to diagnose the problem this season.  Guess I better turn that appointment into an oil change as well so I don't completely waste my time.
Took it in.  Freon was low.  No leak detected.  Dye added in hopes of finding the leak.  Still not sure that was the cause as it only failed on a 100 degree day, but perhaps.  Unfortunately, no more 100 degrees this year. Got my heater plug cut off and an unexpected bonus :-(
If the evaporator has a tiny leak I don't think the dye will show due to it's location. I hope it's not the evaporator.
Mine goes in for the second time next week for weak AC on the drivers side.  Last time it was 0.2kg low on Freon.  Worked fine for a month, now it's failing again.  I suspect there's a leak even though they pressure tested it.  They said they should have put dye in last time, so hopefully they can see the leak this time.  If not it'll be a recharge and dye, and wait for it to fail again.
It's not the sun overheating anything, its cheap rubbish made parts. Go look at the 14-18 forums to see what great pieces of crap gm a/c parts consist of these days. Mine lasted 3 1/2 years at least, and 32k before it decided to leak from oh the lines, the evap, the condenser, only original piece left now is the compressor and i heard those are not much better. Looks like they are using the same low quality components that are guaranteed to fail at some point.
Edited by BIGDOGx
  • 9 months later...
2020 GMC Sierra 1500
Sounds like I have the same issue as some of you.  Driver side air conditioning is not cold.  Took it in with 1200 miles - refrigerant was low.  Service re-charged refrigerant and put in green dye.  Same issue came back 3 weeks later.  Refrigerant was 50%.  Clearly a leak but they cannot detect the leak.  They are saying they may have to replace/repair the evaporator (which is a pretty invasive fix).  Possibly the condenser.
Has anyone had this issue resolved?  What was the solution in your case?
I'm having the same issue now on my 2019 Silverado. Air cold on passenger side,  hot on drivers side with temps set at same level. Will be taking it in this week to check it out.
It never goes back the way it was always something after that seen alot of that at the dealerships
yes sir just as bad if not worse here the amount of plastic is insane
I will now be on my 5th attempt at fixing it later today.  Anyone ever get a resolution on the drivers side no AC?  I've had 3 recharges, and 1 damper accuator replacement.  No luck still, and no sign of the dye from the leak.  I have a feeling my truck will soon look like truck pictured above.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
