Hi FiatDale,
OK, I've been following your thread but am now just a tad confused.
If I read you right, in order to do this addition you need the following parts:
1- Lamp With Camera
2- Complete spoiler
3- Front Coax
Any other parts?
Questions:
Is the coax a simple 2 conductor wire with a shield and inner conductor?
Is it possible to cut off the GMC connectors and make your own cable with BNC connectors?
For the insight of those who want to emulate your project, may I ask you to post individual photos of the components with their part numbers and approximate prices?
This looks like it ends up being a rather expensive project.
Thanks, Steve
You need the mirror too.
But yes, I'm hoping the guy posts a full post with pics and all part numbers.
In all honestly, it would be best to create a new post with all of those in it.
Also saw that spoiler part online last night for less than $200, but I'm not buying anything until I can see how easy or hard it is.
The spoiler is definitely not $200. Used on eBay with camera are around $300. List from GM is $430. If you found or that cheap, chances are it’s a 3rd brake light without camera. As I believe GM has fixed them so they don’t leak anymore, so that’s something you’ll risk with a used one. GM isn’t going to warranty it if it didn’t come on the truck new. You need the mirror, coax cable and spoiler with camera.
Rearview Camera:
3rd Brake w/ Cam: 84487008
Rearview mirror screen: 13532977
Coax cable: 84335461
It’s a simple coax, but without the connectors you are not going to make your own dot rely on splicing, I don’t care what kind of wiring guru you are, do it right. Especially when the cable only costs $30.
Ah my bad. That’s JUST the lamp. Not spoiler. The deal is the harness on just the light is not long enough to extend into the cab, it needs the extension which is tied into the 3rd brake light harness which brings it inside. The coax going from the mirror to camera is not long enough to reach just the plug on the camera / lamp, it needs that extension which is NOT sold separately, only with the complete spoiler assembly
Fighting Major ..... I'm with you.
I'd like to see a parts description with part numbers and prices all in one place.
As for having to buy the entire spoiler .... there must be a work around.
What I'm hearing is that you first need to buy the light and camera assembly, then a new spoiler only for the cable.
$300 for the spoiler with a cable sounds absurd when I know I can make a cable. Connectors are just that ... only connectors.
Cutting off proprietary connectors and swapping them to BNC is no big deal.
Both male and female inline connectors are readily available for under $2 each. a short length of RG194 coax is under a $1
Steve
I don’t think either of you read what I’ve typed. Here is what you need:
Spoiler assembly with camera (black) 84515287
Mirror 13532977
Coax cable 84335461
You do NOT need to buy the PN I ACCIDENTALLY put for the camera, that PN was for just the lamp/camera assembly. It does not have the additional length harness to reach inside the cabin. This piece being on the roof and not wanting to slice thru the grommet and throw some cheap silicone on it in fear of leaks, I would suggest getting the spoiler assembly PN above WHICH COMES WITH THE LAMP AND CAMERA & ADDITIONAL LENGTH HARNESS. Maybe you’ll even get lucky and the clips will be tighter than before so it won’t do the spoiler pop we all experience.
You guys are making this way more difficult than it is. It’s 3 parts. Yes they’re pricey. Yes it’s cheaper to buy these options when built new. You want to save $20 by making your own coax cable and splicing off ends go right ahead. The lead off of the mirror is about 1”. Try not to screw that up on a $500+ mirror. If you’re already spending close to $800, what’s another $20 to make it as factory as possible with a pre terminated cable.
  • Like 7
Thanks for clarifying and sounding like a pompous ass in the process.  Possibly had you just posted the parts and process you wouldn't get questions.  Please don't let us peasants take up your time king rearview mirror installer. Sorry for questioning your mistyped part numbers. I'm sure your servant will receive many lashes for the error on their part.
K it works. Zero programming needed plug and play. When I have time to compile everything I’ll do a whole write up. Get your parts on order.
  • Like 6
Thank you FiatDale for making this happen! I for one greatly appreciate your time and money spent to figure this out. I’m also following your thread in the HUD display, I may have to choose only one to do for now though do to the cost of each. Tough choice!
thank ya!!!!
Outstanding! I have a local salvage yard that has a couple 19s, hopefully I’ll get lucky tomorrow and score some parts for both projects!
First off thank you FiatDale for the update and part numbers I’m ready to order and can’t wait to retrofit my 19 LTZ. Also following your HUD thread and want to do add that as well down the line but was wondering how hard is it to remove the spoiler? Did it involve removing inside headliner completely? Thanks again for all the info
Edited by NICK19LTZ
I’ll do a write up, but it’s tricky to not screw up the headliner by putting a crease in it. Also, I use air tools which made things 10x easier because some of the 10mm are hard to get to with the headliner in your way.
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
