Update on my 2020 trailboss I bought 5 months ago.  Failed to start right after I bought it and they replaced the fuel pump module.  It now happened again 5 months later.  The first time 275 miles on it and now 13000 on it.
I am so glad I found this thread and so disappointed that so many people are having the same issue. I have a 2020 Silverado LT Z71. The third day after purchasing the truck it wouldn’t start, all the same symptoms as everyone else. I was told it was the fuel control module. The dealer picked my truck up, replaced it and it drove fine for about 3 months. Then it wouldn’t start again. Dealer had it for a week and couldn’t find the issue. I was able to take videos that showed low voltage and check engine lights although they weren’t on at the dealer. They gave me the truck back and about a week later it didn’t start again. They had my truck for about 2 weeks and finally said they received the ecm bulletin. They replaced it and today after getting gas the truck took a while to start, but did not crank like the usual problems. So I began looking around and found this forum. I am expecting another issue soon. I have filed cases each time with GM since the first problem and am currently dealing with them now, they have no answers and so far I do not have high hopes. I will be following this thread to see what others report back with.
Edited by 1035Z71
7 minutes ago, KZ3 said:
They are replacing the ECM in mine now.
Interesting.....
I read several pages here and it seems mine was the same as the OP's.  I had JUST washed the truck that day and the GM floor mat was nudging the gas pedal just enough to cause a crank/no start condition
Seeing a pattern here.  Same issue with my 2020 6.2l wit 4,700 miles.  After sitting for 1/2 hour it finally started and I drove it straight to the dealer.  (then walked 5 miles home; vallet service cancelled because of Covid)  Check engine light came on.  Will report the outcome.
Interesting note after reading these posts.  The fuel pump always activated when I opened the drivers door in the morning.  It didn't do that this time.  Always wondered what was going on.  Figured it pressurized the fuel.
On 11/26/2020 at 6:46 AM, Chris Dubois said:
My dealer is saying the problem may be the aftermarket dealer installed alarm.....Karr security system.
They removed the alarm, 3 stops later it did it again... it will be back in on Monday.
November 2020, GM posted a service bulletin for this; PIP 57335F.  The fix is to replace the ECM (Electronic Control Module), so that is what they are going to do.  Will let you all know how effective it is.
Has anyone had the ECM replaced? Did it solve the problem?
In June they replaced my ECM and fuel sender when this was an emerging issue. It worked for me. No issues so far!
I don’t think the 3.0 is listed on that bulletin, but I’ll push for it. Thanks for the info!
Happen to have any more specific info on this service bulletin?
Welcome to more goodies in vehicles = more problems.  Sorry you have to deal with it, but yes, all these newer modern vehicles are not meant to be occasional grocery getters and no other use.  I'd recommend having a battery tender installed.  Plug it in at home, unplug when you need it 5 days later, and so on.  Also invest in a good jump pack.
I have a Corvette. It sits all winter and is only a toy for occasional use. Yes it sits long enough to need a battery tender. But if it sits a week or 2 it doesn't need it. It has all the same goodies on it. It always starts. Not being a daily driver on a modern loaded vehicle is not the problem.
Sent from my SM-A505U using Tapatalk
Sent from my shitty SM-A505U using ******-a-talk
Sure it is... Don't believe me?  GO visit the other manufacturer forums.  Having the same issues.  Too many goodies and computers being run even when the vehicle is off.
Sitting and draining the battery is a different issue.  This is identified as “cranks but doesn’t start” and that’s the title of the bulletin.  Plenty of power in the battery but it is as if it isn’t getting fuel.  In regard to the occasionally driven cars, even the factory alarm and those other goodies will drain the battery in time.
    xdieselmechanic
    xdieselmechanic
  • Who's Online   3 Members, 0 Anonymous, 462 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
