Add me to this list too. I love how this truck looks and was having a hard time finding one in my area so I bought it used. It's a 2020 Custom Trail Boss and I got it with 8,000 miles. The first time the truck did not start was when I took it off-roading. Literally the worst place for this to happen. No service and no one around. After about 30 minutes the truck finally started. My initial thoughts on why it may have happened is because I was parked on a slope with little gas. I brushed this one off since the truck ended up starting anyway.
Fast forward a month and the same exact thing happens but this time I was in a grocery store parking lot with about 3/4 tank. At this point I knew there was something faulty with the truck. I called a local tow company and as soon as the guy arrived my truck starts up. The tow truck driver told me he has been seeing this type of issue on new trucks and did mention GM vehicles.
I love this truck and would like to keep it but it would be unfortunate if this were to happen during an emergency. That reason alone will make me want to get rid of it. I scheduled an appointment with my local dealership and will update once I hear what they have to say.
I should have gotten a Tundra. GM might be the new Ford lol.
*******Update********
3/14/2021
Dealership completely took care of this and haven't had an issue for several months. I forgot exactly what they said but it was something along the lines of a software update that was needed. I'm glad this worked because this is a beautiful truck and would have been sad to settle for anything else.
Edited by IOA
Update
GM will now be offering military type sleeping bags and MRE's at a discounted price when your brand new GM truck leaves you and your family stranded out in the middle of nowhere in the dead of winter.
  • Haha 1
Mine has been fixed since June with 11k trouble free miles since then. You'll notice there are multiple failure modes described in this thread, nearly all of them described fixes that worked.
On 12/28/2020 at 10:41 AM, Kevin Medeiros said:
Anyone have this fixed yet? I'm thinking GM may have no idea what's actually going on with these issues.
Haven't had a single issue since tightening the UBC bolts. That did the trick. Runs like a champ now.
What are the UBC bolts? I'm not a car guy, but I've installed batteries, changed fuses and installed hoses/belts before without any issue. What am I looking for? If it's just a matter of tightening some bolts I'd rather do that than have the service guys mess with it.
19 minutes ago, Chris Dubois said:
I have the 3.0 diesel and has been in the shop nearly 30 days for the crank no start issue. I was just give the replacement or repurchase option.
Wow, that seems extreme...crazy. It's only happened a handful of times for me so far.
Read this and decide whether you want to do this or your dealer tech.  It's very easy IMO, but be careful.
Bulletin (PIT5756).pdf
Edited by Steve-2019
Yep... that's what did it for me. I meant UBEC bolts... sorry for confusion... essentially the bolts that secure the fuse box to the body of the truck under the hood. If not tightened, it may not be properly grounded. This solution has worked for me and a few other folks, but not all. Worth a shot and probably something you can easily do -- at the very least show your dealer this bulletin.
You can add me to this list.  Tried to start the vehicle, cranked slowly would not start.  It usually starts after waiting 3 to 4 minutes.  It happens almost every time I start the truck.  The dealership in my area will not return my calls, my wife is pregnant and I can't drive her car due to a previous accident.  So what happens when my wife goes into labor and my car doesn't start?  I guess I'll have to bite the bullet on a $5k fine for driving her car with no insurance.
  • 2 months later...
On 12/23/2019 at 12:51 PM, Icefisher said:
I am embarrassed to report my issue was operator error.
When I was washing my truck, I cleaned the Weather-Tech Floor mats.  When I reinstalled them, I accidentally covered the accelerator pedal.  By doing this, the vehicle will turn over but will not fire.
I didn't feel too bad, because it took the tech 5hrs to find the issue as well.  My dealer was really cool, and did not charge me a dime for the issue.
This just got my boss's truck up and running as he thought he was dead in the water.  Thank you Google and thanks to this forum!!
  • 3 weeks later...
Add me to the list to 2021 GMC Sierra 1500 3.0 ,100 miles on it.Stopped at hardware pushed start button and it just turned over for a couple of minutes without starting.Kept pushing start button to get it to stop but nothing would stop it,then it stopped.Pushed button again it started up.Took it to the dealer for exhaust leak in the cabin(incomplete weld around valve,below turbo)and to check the not starting problem.Replaced valve and said the no start problem did not leave a code and gm has no info on this lol.100 miles on it and two major problems.Gm’s quality control is disappointing.700 miles on it now and it has not done it again yet ,but it looks like it could happen again anytime.Traded my 2019 Silverado 5.3 new body style.Had brake failure (Almost slammed into a back of a car at my granddaughters school) and multiple recalls.Im a gm person,I own a 2010 camaro from new,my wife has 2020 equinox and owned at least 30 others over the years and never had a problem.
Well it happened again in my driveway ,900 miles on it.Heading to dealer tomorrow.strike two!!
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
