Found a dead mouse when I changed the cabin filter in my last 14 Sierra. Must have got in through the cowl somehow.
1 hour ago, jbugj said:
Those saying GM has no responsibility have kind of been shut down by GM...I looked at a 2018 model and I see GM has fixed the problem of the gaps at the end of the cowls.  Apparently they do feel it is their responsibility to some degree to make them mouse proof.
Auto and home manufacturers make reasonable efforts to build in such a manner as prevent intrusion from rodents and or water.  They're constantly finding ways to improve in efficiency, safety and function.    I don't see where anyone has been shut down with respect to your concerns and I wouldn't be surprised if we hear from an owner of an '18 or '19 who had to deal with a unwanted rodent intruder.  Best to continue to make efforts to avoid such encounters.
Edited by Donstar
yep...all owners want is a reasonable effort of engineering to keep mice out.  That being said, we all know they will still get under the hood and possibly create problems there.  But I'd rather not have them building nests in top of the cabin filter, pissing and defecating on it, then those smells and possibly diseases and viruses being fanned into the cab of the vehicle.
That being said, some people are ok with mice living in their house also.  Gross.  I don't believe any ever got into my home as a result of the home builder's actions.Might have had a mouse one time years ago, and probably got in when a door was open.  It had a short life...
Found a huge mouse nest after noticing a strong odor coming out vents,  laying on top of cabin air filter. 2014 Sierra. I'm trying peppermint oil dripped on cotton balls and also moth ball bags placed in my garage.  Will see if this helps. Mice suck!
Had them getting in my GMT900, never did figure out how though. Lots of poison outside around the house and driveway seemed to do the trick.
Nothing like having a mouse run across your foot while driving down the highway will cause quite interesting diving maneuvers.
  • 1 year later...
Since I have put in the folded up window screens in the gaps at the ends of the plastic cowl, I have not had a mouse get into the hvac and cabin filter system.  So much for the naysayers saying they'll just chew thru it and to just live with nature...
I can honestly say that I have never had a mouse in my vehicles, but I have had a squirrel chew up the O2 harness(es) on our '10 Mustang, spent $80 to have the harness rebuilt, versus $250 for a new harness.  Other than that, we've had ants and roaches, in Okinawa, but we threw ant/roach baits in the trunks and under the front seats, problems solved.
Got them in the wife's Honda once. Mouse trap and peanut butter had him dead in under 5 minutes. He was making a nest in the glove box. Started letting the cat in the garage at night. She's a great mouser.
Cat eats mouse mouse eats Vore, Gulp, Swallow, Whole, Cat GIF
Mothballs and dryer sheets are supposed to help but mice get in the tiniest holes.  As mentioned you can’t completely seal up a truck or house.
That's why we all should rescue a cat from a shelter (or save one or two or three from the streets) ... my four cats often sleep under my truck and BMW at night, (or during the day depending on what I leave at home instead of driving) never an issue here.
Also, neighbor had a rat issue under his house a few years ago, I wound up burying four rats before the pest control company even showed up. :)
Edited by MikeBMW
  • Thanks 1
Till the cat climbs on your paint does a dance and leaves claw marks.  We have indoor cats but not trusting them to not climb on or into myself 🤣
I’m surrounded by woods. I always have at least 3 stray cats around at all times. Never had a mouse problem in 22 years. Two vehicles stay outside. Two inside. The cats sometimes go in the garage. In the spring I have a fox, rabbits, deer. Haven’t seen the armadillo for awhile, so no holes. The dogs don’t room free. The have the deck and a fenced area. I put mothballs out around their area in the spring to keep out the snakes. But no mice.
Nah, claw marks just scratch the surface - easy buff out.
Ask me how I know. :)
Ok, how🤨?
  • Haha 1
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 502 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
