High output alternator??? Anyone found one or put one in yet? mechman doesnt have one on their web site yet. :(
2019 Denali 1500
Ok. Discovered that the 2018 alternator should be the same. Since ordered a 370 amp alternator and a Big 3 upgrade. Will install and let everyone know how it works.
  • 8 months later...
So what was the out come from this? Did the alt from the 2018s work with no issues?
I never installed it. Still have it in a box and contemplating still doing the install. You done it yet?
Nope I have not. I was hoping you had gotten around to it so I would know if this was a possible solution. I'm trying to find a way to get more power as well, gonna need it to feed the audio system I plan to install
Just wondering if anyone has installed a mechman 370 amp alternator onto a 2020 gmc sierra 6.2L engine yet??
My motor does not have a belt tensioner and has what mechman calls a “stretch belt”
says it cant be done unless i just install a 250a alternator and that isnt big enough for my audio needs.
The OEM stretch belt will work on the 370. I havent installed myself but measured a new OEM belt and sent the specs over to mechman and they say it will be fine. The OEM pulley is 55mm and the mechman is 46mm.
This info came from Richard at Mechman.
The bigger problem thay I see is the 200a fuse block that is built into the battery terminal. It should be as simple as disconnecting that and then running a new HOT wires from the alt to the battery terminal with a 400a fuse in between.
I dont know enough about alternators and the GM computer to know if thay will cause other issues or not.
Any ideas???
Any ideas???
I dunno but I guess I’m going to tackle it no matter what. Already spent around $7,000 On this Sundown Audio system and I’ll be damned if I’m going to let a damn alternator stop me from having a bitchin stereo in my new truck.
This is what my battery looks like. It’s about to go bye bye as I have two Limitless Lithium  45AH lithium batteries to use (90AH combined) total weight 36lbs and has the power of 18 AGM 50lb batteries :)
The Police Package Tahoe gets a 170 Amp high output alternator and 720 cold-cranking amps primary battery and 730 cold-cranking amps auxiliary battery (dedicated to emergency equipment) With all the gear that a police vehicle has to power, they have this pretty well covered, you might consider going that route?
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
