I hope I am wrong but, I think they are engineered to fail just after the warranty runs out. 36 month battery last just a touch longer than 36 months. They make good money selling these things.
And there are really only a handful of battery manufacturers. They just re-label them for whomever wants a battery.
I have two vehicles that have after market alarms. If I don’t drive or charge them every two weeks they wouldn’t start. They fail completely in two years. My daily’s usually go 4-6 years. This is in south Texas heat.
Talk about irony. We have been on vacation for a week or so. My truck hasn't been driven in a few weeks. I went to move it today and it barely started. WEAK battery! I was just going to wash it. I put my charger on it and after about 2 hours it says BAD BATTERY. I will have had the truck 4 years on October 23rd. It is a 2014 truck but I bought it from the dealer on Oct. 23, 2015. Could be the original battery.....I"ll have to check the date when I get it out.
Yet my ‘84 is only on its 3rd battery in its life. My ‘86 just received its 4th (after 7 years). Yay for voltage draw.
19 hours ago, khaledsamy36 said:
Almost all the cars batteries I owned runs exactly 1 year , you guys are talking about 3 or 4 years which is for me is a sci fi emoji23.png
Me too!  The added time if any on your new battery probably not worth the price imo.
One thing I love about my other car ( 2015 f150 ) “only one thing “ ,when the battery is low it gives you like 2 days of continuous notification and alarms that the battery is bad - not die all of a sudden like this
hmm..I like that!  You would think by 2019-2020 we would be able to have a digital readout or computer constantly reading battery voltage and algo's to when the dummy light finally comes on and you know it's probably couple more starts before DEATH!  With the K-2's you get NADDA...just death!
On 10/12/2019 at 10:42 AM, 15 Z71 said:
I dont really understand these batteries. My wife's 2011 acaida still has original battery in it. Almot 9 years old. My 15 Sierra battery barley made it little over 4 years...dead.
My beater is still on the same battery I had installed when I bought it used in 2009. I had them replace it because the original was weak. But 10 years of Wisconsin winters later, it still starts fine. And that car is not driven daily, more like 3x a week. My wife got 8 years out of her old car battery, too. I've only had to replace a couple batteries in 20 years of driving. Seems like they care able to last a long time as long as it doesn't start out defective.
Yup. I have a Deka AGM I bought back in 2008 for my SRT8 Charger and ended up being too tall so it never went in the car.  It's been my winch battery for my trailers ever since and it doesn't get charged on the trailer... only off the charger in the shop.  Still perfect... pulled my K5 on the trailer the other day with it lol.  If I don't get 7 to 10 years from a battery it was junk.
I replaced the battery today. It may have been the original to my truck. The battery was manufactured on 12/05/14. My truck is a 14 but I purchased it in October of 15. $174.75 and it should start for some time.
One thing that I was surprised about is I had the battery out of the truck for over 2 hours. When I started it up, the radio presets were still set and the temp settings were as I left them.
I've seen quite a few of the new, super expensive AGM batteries failing prematurely. Most batteries have a 18-30 month warranty with an even longer pro-ration.
GM did a re programming after the battery change - they said lots of functions may fail if not reprogrammed
That's weird. I was really worried about that because I love my TuneSelect (got the max number of saves allowed) so I used a saver cord and hooked up my DieHard out of my Cadillac. Worked like a charm.
    DWic
    DWic
  • Who's Online   3 Members, 0 Anonymous, 699 Guests (See full list)
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
