Huge difference, large mpg loss 65 mph to 70 mph. Any idea what may be causing it, my gears?
I commute 5 days a week on my 5.3L/6 speed, been doing it for years. Did it on a 2014 double cab and a crew cab. Crew cab was a few hundred pounds heavier.
Really didn't notice much difference in fuel mileage between the two to care about.
Bear in mind, I'm in Florida and the road is flat as can be. We get windy days, but I've never paid attention to that. But wind can be pretty restrictive.
Sent from my SAMSUNG-SM-J727A using Tapatalk
What do you mean flat?  What about all them hills (highway overpasses) every mile or so?  ?
There does seem to be a slight grade to I-95, we get less mpg going north and better heading south, generally speaking.  The grade is contrary to prevailing winds, on the east coast anyway.
I was getting readings of 10.5L/100km (22.4usmpg) on stock tires. When I put on my 33x12.5 10 plys I get on average 13L/100 (18mpg) at 65mph if I up it to 70-75mph I am looking at 15.5L/100 (15mpg). 33x12.5R20, CAI, 6.2L 8L90e 3.23. It seems to shine when im on the slower secondary roads at around 40mph, I can get it to 19-20mpg
Edited by L86 All Terrain
Loss of mpg’s will definitely happen every time you’re adding larger tires. Considering my truck is lifted, running heavier wheels and tires, I’m definitely good with what I’m getting. Mostly depending on wind activity, I’m averaging 18-20 mpgs on the highway at 65-70 mph, 17-19 mpgs at 70-76 mph.
Sent from Above
^ Yeah nice truck. Lots of members here will tell you they have a 6" lift on 35's and get 24mpg at 75mph, it's just not the case. But comparatively my current truck has about the same mileage as my old 1998 350 on 29" highway tires, and I have nearly double the HP on tap. My 2010 5.3L on 33's was better than my current 6.2L on 33's.
But nowhere near as fun when you stomp on the gas pedal!
What do you mean flat?  What about all them hills (highway overpasses) every mile or so?  [emoji3]
Hell I can't tell. Been driving it for years between Eau Gallie and 46.
Sent from my SM-J810F using Tapatalk
Nice area, good times at the Titusville Rifle and Pistol Club.
  • 11 months later...
With my 6" lift and 35x12.5s I get about 22mpg at 60, 20 at 65 and about 17 between 70 and 75.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
