Headlights too bright?
Does anyone else with a sierra or silverado get flashed constantly at night?
Seems that folks think the highs are on even though they aren't. Coming from a Wrangler that had horrible headlights I appreciate the lights on these trucks, but oncoming traffic doesn't haha.
My truck isn't lifted or anything so the lights cant be that far off, never touched them so factory setting still applies.
Thanks.
  • Replies 86
As I understand it I have some type of Intel beam they dim when they see a car coming. Maybe others know more.
It’s my understanding 2016 came standard with HID’s due to lighting complaints.
Maybe they’re just adjusted high from the factory.
It happens to me on occasion.
That only works if you have the high beams on, little "A" symbol on the dash once you activate it.
It senses oncoming traffic and dims the lights, then turns them back on after the car has passed, does not work when the fog lights are turned on.
Thanks.
Yes, they are bright, trucks sit higher than cars, so it happens.
Few threads on here about lowering them down, which I do not like the idea of because now your range has been diminished.
Obviously trucks sit higher, but this is everything from cars to other pickups and semis. I don't plan to change anything just making sure its not just me.
Thanks.
Yes!  I had to aim mine down before I lifted my truck as I was constantly getting flashed
Park on a flat area, aiming at a wall 25' away.
Measure the center of your headlight, then walk to wall and measure the cutoff line on the wall. If the line is not about 2" lower than the headlights, then your aim is too high. And that is why you are getting flashed.
These new lights are basically just high beams with the top of the beam cut off. If your aim is too high, you are literally driving around with your high beams hitting every oncoming driver. I wish law enforcement would watch for and ticket people with badly aimed lights. Gone are the days of 2 filament bulbs that are actually dimmer for "low beams".
You are right, a friend/officer in town asked me about them. He couldn't believe how bright they were and initially assumed I had my brights on. I'll check the aim this weekend. Like I said, these haven't been touched from factory settings, so if anyone aimed them poorly, it was GM.
Not you, just bright lights, was just using the term "car" as an example.
Look directly into any car's headlights with HID's/LED's being even worse, they are all same.
The dealership should still have the testing equipment to determine if they are aligned correctly or not.
1 hour ago, BringTheRain403 said:
What year and trim level is your truck?
Sent from my Pixel 4 XL using Tapatalk
2018 Sierra Z71 SLE
I get flashed all the time, but my truck is leveled and I put LEDs in since it came with halogens from the factory.
Sent from my SM-N975U using Tapatalk
Did you do it the ricer way and throw them in the reflector housings of the 14/15 LT Silverado's or in the projector setups of the LTZ/High Country? If it is the latter then you need to adjust them down. The last thing you want is some elderly person hitting you head on driving a two lane at night because you blinded them...
Tyler
