I am glad I can come to this community and ask questions but so pissed off the damn dealership could not tell me. I spoke to them and they said "We will find out for you". They never called me back, and yes I rang them up a second time.
Anyways, my 2014 GMC Sierra All-Terrain - 5.3L took E85 Flex Fuel. Any car or truck with a yellow gas cap will take it.
My new 2019 GMC Sierra AT4 - 6.2L has no cap and I can't find written anywhere if I can use the E85 Flex Fuel in it or not.
Anyone know?
As I understand it neither the 5.3 or 6.2 can run e85. The reason being is ethanol absorbs water if it is in the station storage tank for extended periods especially this time of year. Once it absorbs the water it turns into a white sludge  and can clog things up. I am not a scientist this is what I was told.
The current DFM 5.3l and 6.2l are NOT E85 compatible at this time
The 2019's for the 5.3 and 6.2 are not FF.  Makes me mad that they didn't offer it.  I still run a 50/50 mix of E85 and Premium in mine.  Same goes for my 2002 Silverado.  It isn't flex fuel but I do the same, 50/50 mix.  Love the way they run with it since it boost the octane up nicely.  Not to mention I like the exhaust smell. :)
My 2014 1500 is supposedly E85 compatible. Has the bright yellow gas cap and a big yellow sticker under the hood. I've not used anything more than E10 and hope to never have to. We still have a few local stations with non alcohol contaminated gasoline and about every 3rd or 4th tank I'll try to use that. About a dollar more per gallon I think, but it makes me feel better.
That alcohol gas is terrible on my o540 airboat engine. The valve seats in these old motors need that old gas with the lead in it to keep the valves lubed. We constantly have to add 'Lead Substitute' even with no alcohol. However, the alcohol gas does make them run a little cooler down here at sea level. That's a plus.
Regards,
jumpinjoe
Regards,
jumpinjoe
We've decided that the old two stroke in my dad's boat doesn't like ethanol so we put premium in it and it runs much better.
The 2019's for the 5.3 and 6.2 are not FF.  Makes me mad that they didn't offer it.  I still run a 50/50 mix of E85 and Premium in mine.  Same goes for my 2002 Silverado.  It isn't flex fuel but I do the same, 50/50 mix.  Love the way they run with it since it boost the octane up nicely.  Not to mention I like the exhaust smell. [emoji4]
You actually use 50/50 Super/Flex and zero issues? I just started doing it with 5 gallons of E85 per tank of super
Sent from Above
Appreciate all the replies, glad I asked instead of just adding it in LOL..... Shitty they did not set the newer trucks up to run on it. My 2014 Sierra loved the E85 juice I gave her.... :)
Regards,
jumpinjoe
I ran full tanks of only E85 in my 2014 and she loved it. I did 5 tanks on Premium and 5 tanks on E85 and compared notes.
E85 cost less, higher octane, truck ran better BUT it did not get as many KM's out of a tank as the Premium did. In the long run Premium was cheaper to run. But I still ran E85 every 3 or 4 tanks. No mix, just straight.
Isn't the FF an available option? Somewhere I got the idea it was.
Regards,
jumpinjoe
Just gotta know what kind of 2 stroke motor is he running? We don't see any 2 strokes down here where we run. Thanks.
Regards,
jumpinjoe
Sent from Above
Yes,  a 50/50 mix no issues.  Been running it that way for over 3 years now.
Regards,
jumpinjoe
Sorry, that's on his ski boat, not an air boat. I can't remember for sure what he used to run on his remote control boats and air boats but I can ask him.
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
