Diesel is a great fuel too. Maybe you should mix a bit of that in your tank lol.
This forum has an odd obsession with putting fuels in these Trucks that they aren’t designed to take.
It’s already mixed in the fuel and my only reasoning for adding some extra in my tank is for its cleaning abilities “ONLY!”
Sent from Above
On 10/24/2019 at 5:36 PM, Black02Silverado said:
The 2019's for the 5.3 and 6.2 are not FF.  Makes me mad that they didn't offer it.  I still run a 50/50 mix of E85 and Premium in mine.  Same goes for my 2002 Silverado.  It isn't flex fuel but I do the same, 50/50 mix.  Love the way they run with it since it boost the octane up nicely.  Not to mention I like the exhaust smell. :)
While adding some E85 up to maybe E20 is ok as the ECM is programmed up to E10 with no issues, running E50 can and will cause some problems up to and including the A/F ratio to be off. AS the E85 percentage climbs the stoichiometric value changes from gas to E85 and actually richens up. If the FF portion of your tune is not enabled (from the factory they are not unless the truck was one that had it as an option, which the 18+ trucks dont have) then the ECM will not change the A/F ration to compensate for the E85.
You will be running lean in your case.
The fuel system in the trucks is more than capable of handling E85, even the ECM has all of the parameters in place for E85 but as said there are 2 important parts of the tune turned off that enables those features along with the sensor not being plumbed in.
Anything GM made with in the last 5-7 years can handle and run E85 just fine once the sensor is added and the calibration is changed. Zero issues at all. While E85 is Hygroscopic it isnt like it attracts every ounce of moisture instantly. It is an issue that happens over time, more so if the fuel is left just sitting. AS long as you run the fuel out and replace it and even run a full tank of regular ole gasoline thru the system there are zero issues.
With the gas tank being 26 gallons in the trucks, you can run up to 5 gallons of E85 with zero issues which is 20%. If you run 4 gallons it puts you at 15%, the extra octane will help with detonation that the DI engines are really prone to during the warmer months of the year.
I’ve been adding 6 gallons of E85 then filling the rest up with super, ZERO problems
Sent from Above
I pretty much don't go past a 50/50 mix.  Been doing it for over 3 years  now.  I guess what damage that might occur has already been done.  It is just a matter of time before it shows up I guess.  At least my UOA's are showing no issues at all and are just as good if not better than before running straight premium.  What I need to do is run a scope down the spark plug holes and see what the piston tops look like.
On 10/26/2019 at 9:12 PM, CamGTP said:
There is no sensor and if the truck is not E85 equipped, even the virtual sensor is set to disable. That is done even on the K2XX trucks.
GM has also been setting stoich to E10 ratings of 14.1 since 2014ish. The way the computer can still try to achieve stoich is through fuel trims. It can sense that something is different with the E85 mix that some people run but it can't tell the actual alcohol content. Fuel mileage is still going to be less because of the fact that the computer is smart enough to use the fuel trims to make it run good.
Saying 10-15% increase in power is a stretch. I'd have to go back the wiki page for exact numbers but I believe GM rated the GEN V 5.3 engine at 355hp and 383hp on E85. That is an increase of only 7-8% and that is on real E85. The torque increase is the roughly the same at 6-7%.
Hey bud, I appreciate your energy content on this e85 topic, but we need to square some things here. More on that below.  First things first, the e85 mixing it really does run good at 50-50 mix (93 gasoline and e85).  This is producing an e48 blend roughly.   No engine knock at all, none whatsoever.   If the worse thing that is happening is running rich (Lambda is less than 1.0) that's not at all bad. Engines are designed to run rich all the time, under load, under WOT, in cold temps.
Now, a few things to clarify from what you're saying.  Let's take a walk around the engine shop, shall we?
1) "GM has also been setting stoich to E10 ratings of 14.1"   <-- GM doesn't set stoich.  Stoich is the property of the air content in the fuel itself.  GM sets +/- fuel trim for driving conditions.  The stoich of pump gasoline is 1:14.7, one gram of fuel, 14.7 grams of air
2)  "The way the computer can still try to achieve stoich is through fuel trims. It can sense that something is different with the E85 mix that some people run but it can't tell the actual alcohol content"   <-- The O2 Sensor on the Exhaust manifold is what reads the oxygen content.  If the oxygen is too high, it reports back to the computer, which is then going to send more fuel (Trim up +)
3) Guess what -  e85 has the highest content of oxygen of any fuel source.  The Stoich property of e85 is 1:9.765, 1 gram of corn fuel, 9.765 grams of air.  That might seem confusing, counter intuitive, but realize the lower the ratio gets, the closer to 1:1 parts of fuel and air, essentially we're getting much more air content, with e85.
4) So what does the engine (GM's computer) do when it senses too much air, via the 02 sensor?  It sends more fuel.   That's why I'm getting 14mpg with the 50-50 mix, versus 22mpg with straight gasoline.  In order to optimize the ideal amount of fuel,  we need to think in terms of Lambda readings (not Stoich)   Lambda is the post combustion ratio of what is actually occurring.  Our 02 sensors, I have no idea if they are wide-band, or narrowband. I'm guessing they are narrowband, so they aren't giving the most optimized measurement.
5) Optimized for what you ask?  Detonation, at full compression (not too soon, not too late)
6) For today, is all of this optimized?  Hell no it's not, that's why I'm not running full 100% e85.  The only way any of us is going to be able to optimize it, is getting (1) new sensor, that is a wide-band 02, and a tune that can be set to those updated readings, calculating Lambda.
7) What are those readings going to be?  They are not going to be Stoich pre-set A/F RATIOS. That's not the right way to work with e85.  You need to be using LAMBDA.  A combination of post combustion (wide-band 02 Sensor reading) that accurately tells the PCM,  either too much oxygen a.k.a "lean" (lambda > 1.00) or too little oxygen a.k.a "rich" (lambda < 1.00), and to adjust trim (precisely how much to adjust) and to optimize performance based on the fuel type.  ADD a pre-combustion e85 sensor, that will tell the computer the exact fuel content e85, e70, e48, going into the engine, prior to combustion - so that you can get the ideal detonation at full compression  (no knock, no pre-detonation) just pure, clean, cold, optimized power.
? In the meantime, is this 50-50 thing generating more HP,  cleaner burning fuel, cooler engine temps for longer engine life?  YES, ALL DAY LONG.
Edited by Doolin-Dalton
  • Like 3
  • Thanks 1
Here is just a little proof that "GM does set the stoich ratio to 14.1".
I understand the 14.7 parts air to 1 part fuel for 100% gasoline, it's just that they do not use 100% gasoline in the calibrations anymore because everything can be up to E10 at the pump on regular 87 octane.
GM doesn't set a +/- for the fuel trims, there is no table within the calibration for that.
As said the 02 sensors/fuel trims only report what is going on in the exhaust. These are narrowband o2 sensors and .450mv is what we consider to be stoich. The sensors will show it swinging lean and rich of that value and the trims will show you the work being done to reach that. Be it a negative value or trimming fuel or positive value of adding fuel in real time on the fly.
The main problem I have with people running these mixes is that there is far more to the picture than just what the o2 sensors do. When the E85 sensor shows a higher alcohol content in the fuel, it's changing the commanded stoich or lambda value in the tune. Which also changes the injector functions and timing, it would also change the timing and commanded fueling under certain loads and full throttle. That is stuff that can't be controlled when it doesn't know what is going on.
Thanks for taking me around the shop though, sure did get learned.
I mean I've only been tuning with narrowband and wideband o2 sensors for like 8 years now, I think I got most of this down.
Edited by CamGTP
On 10/24/2019 at 3:57 PM, Mountain boy said:
As I understand it neither the 5.3 or 6.2 can run e85. The reason being is ethanol absorbs water if it is in the station storage tank for extended periods especially this time of year. Once it absorbs the water it turns into a white sludge  and can clog things up. I am not a scientist this is what I was told.
Government benefits to automakers for producing FlexFuel vehicles expired in 2016.  You can safely run E15/Unleaded88 in it or any other auto produced since 2000.
In time some tinkerer will find out and announce whether the computers contain the FlexFuel tables and ability to add Alcohol Content Sensor (Fuel Composition Sensor) like the L83s.
Also run mixes and get my best fuel efficiency and savings with an alcohol content between 16% and 22%.  E85 mixed with 93 usually yields 95 or 96 octane.  Pumping E85 with E15 is much less expensive and still delivers 91 octane.
I know that Cam, didn't believe otherwise.....I learn from it just as much as sharing the info, and from what I learned in tuning my Honda, Lambda is the measurement to use regards to e85.
Back to Chevrolet land, I'm eagerly awaiting  (1) an e85 sensor (2) HP Tuner for our 2019 Trucks so that I can run full out e85.  Until then, I don't believe spiking Gasoline with e85 is hurting anything.   There is obviously a question of how much, I've taken it to 50-50 with positive results.  Reluctant to go any higher than that, without the sensor and tune.
My 2016 Silverado ran full e85 and it was amazing.  My Honda Civic was gasoline only, but I tuned it for e85 using HondataFlashpro and an e85 Sensor,  it too was amazing.  It's not just #s and charts, you will feel the difference in the vehicle.
I can say this much.  When I did run E85 100% in my 2002 Silverado I would get a CEL and the code was for it running lean on banks 1 and 2.  So ever since then I only go as high at 50/50 and have not had any issues since.
I was lucky to be able to add a sensor to our 2016 Suburban really easily and had Black Bear tune it.  It runs great and I sent him a log file after mixing in some E85 and he came back saying it was showing a 35% ethanol level and everything looked good.  Now with a 32 gallon fuel tank and E85 being $1.98 a gallon it doesn't hurt as much to fill up as it would with 93 at $3.00 a gallon.
Doolin and Cam, thanks for the post and great info.  I'm learning more every time I get on GM-Trucks.  :)
My last new truck 2014 ran noticeably different on E-85. It needed less throttle input seemed to shift better. I liked the option to use reg gas on trips. I always had caned tunes since they were available. The combo of transmission tuning, 50 percent TM, higher shift points and E-85 really woke up my truck.
100% agree. I used it as often as I could in my 2014 5.3L as well. Here in Calgary Alberta there is only one station that carries it, a city of over 1.2 million and we get one pump LOL. But I used it all the time when I was in the city and then Premium when on the road..... Made a big difference and I am pissed off it is not an option for my 2019 6.2L
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
