I've used a couple types of grease over the years, to include the red Mobil 1. It never seems to fail that whether I keep the gun in the garage or basement, the grease ends up liqifying. Now I don't use the gun often at all, so I'm not sure if that's the biggest factor, but I thought I'd reach out for tips or suggestions as to what to use and where/how to store it.
  • 2 years later...
Bump this up to see if we can get some discussion.
As for turning to liquid, I started pulling the plunger back during storage. Figure if it's not squeezing the grease maybe it wouldn't separate as fast. Seems to have worked. But I also keep the gun and grease in a temp. controlled area
  • 2 months later...
Valvoline SynPower and Mobil1 grease used here interchangeably through the years, from Autozone. Now keeping the grease gun in the garage instead of the small backyard shed containing the mower, as it is cooler in the hot summer and the grease separates less. I agree with Txab on leaving the handle cocked to relieve some pressure.
Is this a thing up north?  Never had this issue down here in Florida.
Been using Lucas Red-N-Tacky in their grease gun for 6 years now without issue.
Amsoil grease. My grease gun is hung on a nail in my garage handle up. Sometimes it’s 120 degrees in there. Texas heat.
https://www.machinerylubrication.com/Read/1352/grease-basics
https://www.machinerylubrication.com/Read/31614/minimize-grease-bleeding
Quote
New grease cartridges or tubes should be stored upright (vertically) with the plastic cap up at all times. This will help to prevent oil from leaking out of the tube.
If the cartridge is left in a grease gun, the gun should be depressurized and stored in a horizontal position inside a clean, cool and dry area. This stops oil from bleeding to one end of the grease gun by keeping the oil level and consistent throughout the length of the tube.
Edited by elcamino
  • 5 months later...
I used to use Mobil 1, had similar separation issues. I now use red-n-tacky. Never had an issue since I switched. Use it for truck, boat trailer, and travel trailer.
