AFM Disabler?
DenaliX
Hi, I have been reading up on the AFM going bad in trucks. I have a 2017 Sierra and I was thinking about disabling it. Anything I should be aware about before doing it?
my pickup has 35,700 miles. Just got it 5 days ago.
Nope they work as advertised. Buy direct from Range so you know it's the newest software.
Thanks guys. So will this help with the whole lifters failing problem? I’m new to this whole afm thing
Put it this way, it will make the chance of it happening far less because the system will not be working.
The parts are still inside the engine, so because of that a problem could happen someday or it may never have an issue.
Thank you, appreciate your response! I will order it today.
  • 3 weeks later...
Been using a range device since new. Now have 21k miles on it. I hate it dropping to 4cyl! I bought 8 cylinders and want them all the time! The range device works 100% without issues for me so far
Sent from my XT1710-02 using Tapatalk
Range is awesome!!
Just an FYI you can also do the same thing (And user control it) with our new AutoSync and a bunch of other cool features!
Where? Post it up.
Other than some earlier versions draining the battery when parked for a few weeks I never heard of anything bad. All good.
17 minutes ago, dieselfan1 said:
Where? Post it up.
I think he was referencing the AFM system in the engine and not the Range AFM disabler but I could be wrong...
Yeah your probably right. I misunderstood what he was saying.?
2 hours ago, 3tspapat said:
the AutoSync work with eAssist models as well?
If it has AFM it certainly should! (thats a standard so it shouldnt deviate) if it didnt we'd definitely give you a refund thats for sure.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
