Silverado 1500 manual trouble passing the third gear.
Hi and thanks to take the time to read my story.
I just bought a Silverado 1500 6 cil. Mod. 2007
Everything works great except the gearbox make the trrrrrr noise when I engage the third shift. All other works great.
I also feel that the clutch is a bit hard to press... I need more muscle or it's normal.
The first and the reverse engage without trouble.
Tomorrow I will check the oil inside the transmission.
Thanks for your help....
Mateo
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
