On 11/15/2021 at 5:32 AM, Whipped Trail Boss said:
I have a 2021 6.2L TrailBoss and I have added a 3.0L Whipple Supercharger and ECU unlocked by HP Tuners. All the work and dyno tuning has been done by National Speed Inc. They have been able to squeeze 580whp which is pretty close to 700hp at the crank. My truck will keep up with my 2015 C7 Corvette Stingray. To my knowledge HP Tuners has recently been able to unlock the GM 10spd tcm. My shop has confirmed it and they want to wait until HP Tuners offers more adjustability. Currently there is not much that can be done to the tcm even though it is unlocked. I have only had one problem with this setup. After about 5K miles the pulley and main shaft snapped in half while cruising on the interstate at 75mph. Whipple and National speed obviously fixed it for free as it was all still under warranty. If anyone has any questions I'd be happy to help. I'm going to attach the dyno report.
How much power did you loose below 3000?
On 12/21/2021 at 10:44 AM, TNTSilverado said:
Here is an article from motor trend for the performance package from GM
https://www.motortrend.com/how-to/chevrolet-performance-silverado-intake-and-exhaust/amp/
I gained .3 tenths just adding my Corsa Catback exhaust and S&B intake.
Motor trend also doesn't know how to operate a dyno :noway:
https://www.thedrive.com/news/30990/heres-what-happened-with-motor-trends-controversial-2020-chevy-corvette-dyno-test
One would think they would verify findings before advertising significantly more power at the wheels; then the sae certified power rating at the crank...
I read that article last year and it was very entertaining!  But everyone can make mistakes!!!  We all are human. It’s the ones who can admit their fault, learn from it, better themselves, and move on that succeed!
I was just helping the gentleman out by trying to show him that an exhaust and CAI will help these trucks. Especially when it was almost $3k a year ago to tune them. If you look at the article. Look at the stock exhaust and see how even though the flapper is open it still is covering almost 50% of the air flow. When I removed mine my father (who is a retired mechanic) could Not believe that flapper was in their restricting air flow. I know what’s it’s intent is for but it is not good for performance. Try  covering one of your nostrils, only using one side, also not breathing through your mouth, then go for a run!!!  I went to college for track and can tell you it would suck if I had half my airway blocked.
My truck runs way better now and the acceleration is better. Many have proof and this article proves it as well. It lets the truck fully breathe.
I am currently still debating whether I will add a tune or not. I just retuned my ECU in my side by side and am really enjoying that. Woke it up a bit along with removing the governor.
Absolutely. I think if you want an intake, buy one. But how it performs when you first install it, and how it performs after 100miles may not be the same; unless your tuned. Air intakes and their affect is a lot more complicated then google will tell you..
I just ordered a afe intake but there's a 4 month national backorder!
I said I would never buy aftermarket again 😋 The main reason I did was that I need a intake that will fit over a 95mm tb.
On that note! 95mm is pretty much of 0 benefit in my application. But it's something I've been wanting to do.
1 hour ago, Alabama said:
Do you need to re tune after installing a new air intake?
No, it's not required but you would benefit from it 😉
The GM one states you “should”???  I’ve read that some have had check engine lights come on.
I have the S&B on my High Country and also had it on my Sierra SLT. Love them. Very high quality materials, constructed very well, and look amazing. They do not need recalibrated.  S&B just states to disconnect battery for 2 hours and take off the oil filter life in your menu screen.
Thanks I will check it out. I did the rear two resonator deletes and a Rotofab CAI. Not sure if I really noticed a difference since I installed it within the first 500 miles of the truck being new. Truck has about 8k miles on it now and more than anything it feels to have woken up a little after the first oil change… I was thinking of going with a true exhaust system to get rid of the drone I have now. It’s not terrible but definitely not quiet like stock. I’m a guy that wants better sound, as much performance as possible, and little to no drone. By the way it is a 2021 6.2 Denali.
Edited by David Lampkins
I am not trying to pry on how much this setup cost just for the heck of it but I am seriously considering a supercharger and supporting mods for my 2021 Denali. Did you only do the supercharger and tune or did you also install a CAI, exhaust, and change the headers? Also, you don’t have to give an exact cost but about how much out the door is it to achieve what you achieved on your truck? Thanks.
Yes, in my opinion do it right!!  I saved up my side jobs and I do biolife. I only use that money to upgrade my truck. I got my full Corsa CatBack exhaust for $1180 on sale, and the S&B was around $400.  In all I have about $1600 in it and it’s worth every penny. The Corsa is whisper quiet when I travel 80 mph down interstate to my cabin, but very aggressive the moment you step on the gas!  The Borla—-GM Performance Package is very nice also. Many on site have it and state it’s worth the money.
Good luck with your decision and Merry Christmas!!
I have a Cold Air Inductions intake on order for my 2022 LTD Trail Boss (which I hopefully get to pick up this week, if delivered on time to the dealership).  Chose it because it's an easy bolt on using the factory intake box and venting.  So this thread definitely caught my eye.  I figured that the engine would "adjust" to the new air/fuel mixture automatically with all the calculations the new engines do now days.
Is taking it to a tuner after the install really a big difference?  Anyone know of the dealership would apply the same tune change that they would with their own CAI for a charge or if tune shops are able to deal with it now?
Just install the intake and let it be. There is nothing you have to do for that particular mod.
4 hours ago, XstarBrooks said:
Is it still $3k to tune a 2020 6.2L? I’m realizing these posts are from 2019. Thanks for the information.
Here is a choice
https://www.diablosport.com/uncategorized/2021-gm-5-3-6-2-gas-truck-tuning-now-available/
or go to HPTuners website.
Superchips also make a hand held tune.
The local performance shop here  National Speed told me that they could dyno tune my 2019  6.2 and the total cost would be $1,700.  Sounded low to me and asked if he was sure and he said that is the price.  Maybe they have a deal with HP Tuners, who knows?
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
