11 minutes ago, lapoolboy said:
Sweet!  Maybe that means they are caught up now!  I just ordered mine directly from S&B.
Awesome! Congrats on your purchase, let me know how you like it and Ill post pic when mine is in.  Take care
I went with the aFe intake on my less than 2 day old TB 6.2L. Up next is their muffler delete pipe!
21 hours ago, Rick TB said:
just ordered the S&B CAI?
just receive an email, S&B CAI for Silverado are in backorder...
Ugh. That stinks man. I have waited over 2months for mine.   It’s in route Per UPS tracking# and supposed to be here Friday. If this new one is as good as my 18s was. It’s worth the wait.
I did install the Volant. Performance wise it is very close to the RotoFab. I live in Canada so with exchange the Volant is still pretty pricey. But much less than replacing the bottom part of the air box. The performance is good. The fit and finish is good. The pipe is super smooth on the inside, I was worried it wouldn’t be but it is. I wasn’t too worried about the look. I’m not showing my truck.
Bro, where are the pics of your installed intake!?!?  Today is FRIDAY!
 Brother. I’m at work!!   Wife sent text at 6 pm. Said it showed up. I’ll install tomorrow and get pics.
Install is done. Went ok. The 10mm nut holding intake housing box is kinda a pain. Need a small socket set or wrench. The intake cupler was a pain to get around the intake. Fit and finish is good.
Man does it suck in air. You can definitely hear the difference. If u have an after market exhaust it just enhances it.
On 8/23/2020 at 6:05 PM, Rick TB said:
I just placed an order for the Cold Air Inductions filter. Saw this video by a guy who installed it in his Trail Boss, https://www.youtube.com/watch?v=J05bzfs2yTE.
There's another video out there by a guy who did a dyno run with this filter and saw I think 4-5 HP at the rear wheels. Not that impressive, but meh, it's cheap enough and it's something...
edit: found the other video... https://www.youtube.com/watch?v=fwpDqkqBCNg
Edited by BossTaco2020
Dropped the GM CAI in this morning. Didn’t even take an hour. Very happy with it, and can’t wait to hear it paired with my new catback exhaust, which the Chevy dealer is installing in about an hour. ??
BTW, anyone who installed the GM CAI... did you put those zip ties on that came with it? I didn’t see a need for them and the videos I watched online of other people installing their CAIs didn’t show them putting them on. Just curious.
Correct me if I am wrong but I recall reading somewhere that GM's Performance Intake requires a dealer calibration?
Yes.  It is included with the purchase of the CAI.
Thanks Nick,
That being said, wouldn't any CAI require the same?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
