Here are a few pictures of my install. It actually works like it was planned. I measured how much camera coax cable I needed (distance from the trailer to the bumper plug) at the most extreme turning angle of the truck with the trailer. That amount of wire harness was right about 5 ft. I then decided on using that coiled yellow trailer plug/harness and routed the camera cable through the coiled wire. I even plugged that into the bumper to help secure it to the truck. The other end of that coiled wire goes through that round cable holder and its secured to the trailer along with the camera coax cable. You can see that I used a wire tie to keep the camera coax from being pushed out and looping at that location. You can see the loop in the camera cable coax up near the bumper which is exactly where I want that. One of the pictures shows me pulling/stretching the cable like it would stretch as if you were turning sharp. I then let the cable go and it goes back in place with the loop near the tailgate. That yellow trailer harness sole purpose is to keep the 5 ft. of camera cable coax from dragging on the pavement and it works very well.
I hope all this makes sense.
bsmall1564 - How did you attach the camera to the trailer?  I was surprised when I unboxed the camera that they sent bolts to attach the camera to the trailer.  Did you use screws with washers instead?
1 hour ago, McEagle said:
Hi Chuck,
Did the 20' camera extension for the camera that you bought from Pasternack work?
Yes it shows it in that link, it has trailer pics of the back ramp.
Chuck
43 minutes ago, W Tilley said:
So if I am not interested in the transparent trailer view, can I mount the camera high on the rear of the trailer?
Yes you can, I would just experiment the height you chose to make sure you get the image you want. Someone mentioned that they had a fisheye effect on their image and lowered the camera a little until they lost that effect.
I mounted mine high and my image was great.
I’ll also add that I’m rerunning the way I ran the cable to the bumper plug after I pulled the coax line out of the plug.
I thought I allowed enough cable for tight turns on my fifth wheel but didn’t.
I ran into the same issue. Thought that I had enough cable on my gooseneck trailer but broke the coax going into the connector when I pulled the trailer out of the barn and went around my circle drive. I was excited to show my wife the new camera and it was blank when I pulled up the screen - went back to the connector and found the coax had broken off.
I ordered a replacement connector to go into the coax. Also ordering the extension from Pasternack - I'm going go ahead and move the connectors into the bed although I was hoping someday to get cameras on some of my bumper pull trailers.
I sent you a PM ShogunKC.
On 10/21/2020 at 5:17 AM, alaker42 said:
No, if you undo the screws on either side of the bracket, you can rotate the camera the other direction. One drawback is you won't be able to use the markings on the side of the bracket to line up the camera because the camera will be in a different position. I was able to eyeball the angle and it worked fine though.
On 10/14/2020 at 6:29 AM, alaker42 said:
First time poster, got some great tips here on how to mount the trailer camera so I figured I'd post pics of my install in case it helps others.
I have a 26' Travel Trailer so the cable length and hookups were perfect for my setup. Instead of drilling holes for the camera mount, I attached it to the camper with 3M super strength vehicle molding tape. I also placed the camera bracket upside down to avoid having the loop of cable out the top of the camera. I painted the cable white to try and blend it in a bit to the color of the camper. I also bought an extra Camco battery box to hold all of the slack cable at the front of the camper - I just drilled a couple holes on either side of the box to run the cable through. I used Cool J's tip to run the cable underneath through 1/2" non-metallic Liquidtight Flexible Conduit through some of the camper frame cutouts and I attached it in a couple spots with a some Line Clamps.
Took it on a trip over the holiday weekend and it all worked great - love having the rear view transparent trailer option.
Did you have to take the camera apart to get it into the 1/2" non-metallic Liquidtight Flexible Conduit ????
A lot of great info on here guys. Thank you! I am going to be installing mine soon and will update here.
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
