On 1/27/2020 at 3:23 PM, Booger T said:
Is there any good reason to be going faster than that?
Well this is America. Speed limits are for safety of the masses. However, isolated highways, no traffic, extra cash in wallet feeds the need for speed.
The problem is Americans are also free to sue their manufacturers.. so now the manufacturers are exercising their right to put in speed limits. I know I've hit the speed limiter in the 2021 Cheyenne which was intended for the Mexican market. I never went over 100 mph in the 2019 Silverado though.
A thread like this pops up every now and then. From what I’ve been able to find on the subject. It’s more to do with drive shaft speed and the length of the driveshaft. There’s seems to be a speed where the driveshaft losses it balanced and gets wanky. I suspect in mass production the balance is close enough for the masses. If you look real hard all over your vehicle there’s plenty of places you’ll find good enough is the rule. Pretty much how it goes during mass production. If you travel out west where you can fly a few mods will make that happen. At least up to the 14 model my last new truck. When it was easy to tune them.
There is likely more than one thing that determines the speed limiter setting
-- just as there is more than one thing that determines the payload rating and the tow rating.
20" tires shipped on my truck are S rated (door sticker shows this too)
The optional
R3O         Tires, LT275/65R18C blackwall Goodyear Wrangler DuraTrac MT
are Q speed rated
I have a 19 CCSB 5.3L 4WD with a 3.23 rear and 20" rims that came with Bridgestone AT S rated tires.  It was limited to 112.
I did a limiter delete program and the truck will now do 130, barely. 128-129 if there is even a slight breeze for a headwind.  It has T rated tires, and I can state, without any reservation, that the truck can do 125-130 for upwards of 30 minutes without the tires blowing or the drive shaft going kaboom.
Before anyone freaks out, this truck is used as a patrol vehicle.
2021 custom V6 with stock 20 inch rims. My fun ends at 98MPH
I have a 2021 AT4 with 18" wheels. I've gone over 110 mph with it. But the tires it came with are Goodyear Wrangler Fortitude 265 65 18, which has a speed rating of 118 mph. Seems like GM is limiting the speed of these trucks to match the tire's speed rating. So, not necessarily based on wheel diameter.
Has anyone actually "blown up" their driveshaft with proof, like many claim?  I have removed my speed limiter and gone well above what some said will do just that with no issues.
On a closed course... in Mexico :)
I have not but trust me it happens. I've seen it. Not on the newer trucks but on the K2XX especially when doing dyno tuning the driveshaft will grenade. On the T1XX since the tuning is so limited I haven't seen anyone do it just yet.
I have not seen driveshaft blow in person but it does happen. You take a balanced shaft that is balanced at a rpm built into the design and speed and run it out of those specs your at risk as a simple 1/4 oz weight turns into a 3lb weight don't remember the exact numbers and when you take the design out of the spec of the shaft it becomes out of balance and running it out of those specs the shaft will vibrate and come out before you can stop the truck, if you start to feel the vibration its to late. I have seen videos of vehicles on a dyno and the shaft exploded and came into the car blowing right through the floor.
If you look at the safety requirements for a 1/4 mile drag car they all have to have the driveshaft loops installed for this reason.
Edited by Silverado4x4
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
