21 minutes ago, Dcor388 said:
2019 LTZ 6.2 with MTP and 3.73 rear end 106 top speed limited 20" rims
How did you get 3.73 rear end???   I have 3.23. Would love 3.73s. I thought highest  rear end was 3.42s in gas and 3.73 with the new half ton diesel.
I have 2019 High Country with 22s and it shuts off at 112 mph.
Edited by TNTSilverado
Had to order the Max Trailering Package. Has heavier springs and shocks and lower rear gears. Unbelievable difference with the 6.2....bit stiffer rear end ride but worth it for the launch and mid range acceleration
Max trailering package gives ya 3.42s, not 3.73s. I have the same truck, 2019 LTZ 6.2 with NHT (max trailering package).
That’s what I thought. I looked for one with 3.42 but couldn’t find one.
3.73s would be awesome to have though.
2019 T1
    GT4    Rear axle, 3.73 ratio
On Silverado Custom  -  Included and only available with (BD1) Custom Max Trailering Package.
On LT and RST -  Included and only available with (B4U) Diesel Off-Road Package.
On others - not available
Not available on 2019 T1 Sierra
2019 Silverado
NHT         Max Trailering Package, includes 9.76" rear axle, enhanced cooling radiator, revised shock tuning for increased control, heavier duty rear springs, increased RGAWR and (KW5) 220-amp alternator
On Custom -  Required and only available with (BD1) Custom Max Trailering Package.
On LT and RST -  Requires (L84) 5.3L EcoTec3 V8 engine, (Z82) Trailering Package, (G80) locking differential and 18" or 20" wheels and tires. Includes (GU6) 3.42 axle ratio and (JL1) trailer brake controller. Not available with (Z71) Z71 Off-Road Package.
On LTZ -  Requires (L84) 5.3L EcoTec3 V8 engine or (L87) 6.2L EcoTec3 V8 engine and 18" or 20" wheels and tires. Includes (GU6) 3.42 axle ratio. Not available with (Z71) Z71 Off-Road Package.
ON HC -  Requires 4WD model and (L87) 6.2L EcoTec3 V8 engine. Includes (GU6) 3.42 axle ratio. Not available with (Z71) Z71 Off-Road Package or 22" wheels.
Not available on either Trailboss
2019 Sierra
NHT         Max Trailering Package, includes 9.76" rear axle, (GU6) 3.42 axle ratio, enhanced cooling radiator, revised shock tuning for increased control, heavier duty rear springs, increased RGAWR and (KW5) 220-amp alternator
On SLE and Elevation -  Requires (L84) 5.3L EcoTec3 V8 engine, (Z82) Trailering Package, (G80) locking differential and 18" or 20" wheels and tires. Includes (JL1) trailer brake controller. Not available with 22" LPO wheels or (X31) X31 Off-Road Package.
On SLT -  Requires (L84) 5.3L EcoTec3 V8 engine or (L87) 6.2L EcoTec3 V8 engine and 18" or 20" wheels and tires. Not available with 22" LPO wheels, or (X31) X31 Off-Road Package.
Not available on base sierra, AT4 or Denali
Edited by redwngr
Yeah, NHT trucks are somewhat hard to come by. But the dealer here almost exclusively orders them. Pretty much every 6.2 that’s not a Denali comes ordered with it. I had a HC, LTZ and a few SLTs to pick from. The HC was the wrong color and the SLTs couldn’t get the tech package at that time so I landed with the LTZ.
From what I’ve seen, there’s not a big performance difference between 3.23 and 3.42 trucks. They are all within a tenth or two of each other to 60.
3.73 would definitely make a more noticeable difference, but only getting it with a 6 speed or a Diesel is a 👎 from me.
Is there any good reason to be going faster than that?
Some states have higher speed limits than others, and trying to make a pass in those states will require higher speed.
Also, going offroad, such as the Bonneville Salt Flats, and playing around is another good reason.
Both of those scenarios I've experienced. I hit the speed limiter on my Silverado when passing a semi on a 2 lane road. It surprised me. Fortunately, there was no oncoming traffic that I was trying to beat when I made my pass.
Strange,
2020 High Country with 22s and mine shuts off at 106.
10 minutes ago, Cjanik said:
Strange,
Ya. I have seen that too with a few 2020s. Idk if it’s a 2019 thing but I believe another gentlemen on here has a 2019 and his is 112 also. Must have changed it up for 2020. I have the Bridgestone Alenza tires. What’s does yours come with??
Because I want too.......and also,  I quote, “I have a need, a need for speed!”
same tires, Alenzas
Well good for you😐
  • Haha 1
Obviously a recent (past 3 months) software update has reduced the speed limit on mine from 110+mph to 98mph.  Stock 18 inch rims with GY Duratrecs.
2021 Trail Boss Custom 6.2 w/20's hit 115mph on the GPS because my tires are larger than stock. Computer ends your fun at 112mph on 20's, 98mph on 18's.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
    • I may be old school. But I’ll pass. I’ll stick with the old stuff. Thank you.
