On 2/14/2020 at 3:11 AM, Bob2C said:
My 2018 Tahoe is definitely not orange. I bought it new
Is your overflow tank always so low?
8 hours ago, Bigfutz said:
Well, the cap color is more accurate than anticipated. The Prestone DexCool (left) is definitely orange, and what’s in the reservoir(right) is pink.
Thinking someone added water, which is a no-no, I would have it changed out just to be safe.
This is what I keep in the shop, I know it is the right product:
See the source image
Bought it new like that. Level never changed.
I put a block heater in my 2017 Burb couple weeks ago. Dumped in what had came out and noticed it was pink instead of “Dexcool orange.”  Also owned from new so I know it hasn’t been changed. My pink looks exactly like the pictures above.
Is it possible color change from usage?
If it does it changes quick. I have 8k miles now and have never ran it hot or had a problem. I lost a little putting the block heater in and didn’t top it off with Dexcool cause it didn’t match. If I don’t find an answer soon I’ll probably just dump some in. Would be nice to know what it is though.
So I found this on the Cruze forums. Interesting. The second attachment should be read first
  • 5 months later...
I added some Prestone Dexcool to the tank and brought it up to the cold full line. It mixed well and had no issues.
On 2/23/2020 at 9:15 AM, BlaineBug said:
Is Dex-Cool the same awful sludgy mess that it used to be?
Dexcool is fine.  It was the coolant's reaction to $hitty gaskets GM was using that caused all those problems early on and from people not changing it every 5yr/150k.
Edited by newdude
Yes, its Dexcool that is in there.  Yes it does look on the pink side.  Yes its normal and no GM didn't stop using Dexcool and switch to something else.  All the new vehicles have that pink-ish color to it.
I wasn't aware.  Was it an incompatible metal gasket or rubber that was causing the issue?
Shucks, I missed this thread until now. I know it's been pretty much answered in the mentions above, but though I'd comment. So, I discovered my 2014 SS sedan had what appeared to be pink coolant as well. I couldn't find anything online or in the owners manual mentioning this besides "USE DEXCOOL". Earlier this year at a local tool/ parts store expo, I spoke with a PEAK antifreeze rep and he answered the question as they are a supplier for some some/ all of GM's production lines. He stated that (in addition to above mentioning the dye blends), that some of their coolant reacts differently with the metals and rubber seals in the vehicles of some vehicles, altering the color slightly. He said that they are are aware of the the GM Dexcool blend being of a pink hue, and said it's the same composition as the regular orange that you are used to. So, suffice to say, Pink in a GM vehicle = Orange Dexcool.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
