Are you running Michelin Defender?
tbmaciii
I have Goodyear Wrangler STAs and it is time to get new tires. After much research on this site and others as suggested, I decided on Michelin Defender LTXs. I then called the local tire shops and both owners told me that those tires are great highway tires but are absolute junk in any kind of inclement weather. Does anyone here have those that could offer some advice? I will mostly be on the highway but I want something that can handle the snow decently since I am a Fire Fighter and work 24 hour shifts regardless of the weather.
Thanks
They are great overall tires. for firefighting i would think you might want something with a little more meat Michelin A/T2 are also good(not the best) for hwy.
I know my next set of tire for my truck will be defenders. I work at Americas tire and see defenders with 60-100k miles on them.
Thanks
Great highway/street tires, you’ll need to look for something with snow rating, Defenders are not for snow. Being that you’re looking for highway/street style tires I’m assuming you’re wanting to keep as close to your current mpg’s as possible. There are a few AT’s out there with snowflakes on them but will definitely be heavier tires. The defenders are definitely an awesome tire but you can’t have both in a tire without compromising especially coming from the horrible SRA’s.
Sent from Above
I have them and love them...smooth, quiet, drove in the rain once, no funny business, don't know about snow, I would take the "junk" opinion with a grain of salt.
They sell like hot cakes in the winter here, many people love them. 4X4 truck with those are pretty well set in the snow.
There a good tire have them on both of our trucks, excellent on wet pavement. Smooth mine balanced out with very little weights needed. I run gravel roads weekly and there tough. I only use them on highway and gravel roads.
Have them on our 16 Tahoe, head and shoulders much better tire than the factory Bridgestone's that came on it.
So far, they have been in any type of weather Washington state has to offer and done great, went really well in the snow last year.
But, I would not consider them anything other than an A/T type tire at best is you are planning to go off road. They are more suited for street use.
I have them on my 2000 Sierra.  Great tire.  I use that truck for mostly bad weather driving and in Denver, that means lots of snow and ice.  They work just fine.  I've never been stuck with them.  They now have over 60k on them and they still work well, but this will be their last winter.  They don't look agressive at all but they drive very well and have never let me down.  I bought the LT version, not the P metric.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
