Rear Under Seat Storage
Do all 2020 2500/3500 HD's come with the small, carpeted rear under seat storage bin or is that an add-on?  I know the lockable under seat storage is extra but couldn't tell if the carpeted one was.  Thanks.
I can provide you with a  data point:  I did not select the under-seat storage option when I ordered my truck, but it was delivered with the smaller carpeted storage bin.
Unless the dealer orders the larger plastic one (accessory), then they all have that small carpeted one. I used my GM points and ordered the larger plastic lockable one. I just put it into my new GMC yesterday (the only advantage of swapping out the 2020 Silverado for the 2020 Sierra is that they are the 'same'.  You just pull out that small carpeted storage area.
9 hours ago, Ryno12 said:
Mine came with the small carpeted one also. I immediately pulled it out.
My LT came with it installed, not sure if the dealer ordered it or not as I just bought the truck off the lot, but I took it out because it wouldn't hold all of the stuff I had under the seat from my previous truck. I added the full coverage floor mats and unfortunately there was some miscommunication and they cut that full coverage mat to get the storage bin back under the rear seat....
Oh no! That would tick me off. So you’re basically back to square one?! Can you get them to replace the rear floor mat?
I keep so much stuff under the rear seat that neither storage option is viable for me. That & I have kids booster seats in the back so I don’t always want to have to lift the rear seats to access my stuff. I’d much rather just slide it straight out from underneath.
From what I see in the specs and order guides, the smaller carpeted unit is included with Double and Crew cabs on all Sierras, and Silverados from LT up.  The Silverado WT and Custom do not have it.  The lockable bin is an LPO/dealer-accessory option.
My 3500 high country came with the carpeted one. I save the larger plastic one from my 2017 and it fit with some bracket fabrication and had to relocate the jack.
I was on the fence about ordering this box so did not include it with my factory build as I can always get one from the dealer.  Can you tell me, is the lid removable?  Also, it looks like it is designed to hold a couple of rifles, do you know if it 2 scoped rifles will fit in that space?
I suspect that GM didn't want to 'offend' folks so they use fishing poles in the photos. I don't have two rifles to test with myself, so I can't tell you for certain, but it might work. The lids are removable, in fact, you have to remove them to install the bin. Basically if any of you folks signed up for the GM rewards points, after buying a truck you should have nearly enough for the storage units for 'free'.
Oh I was ticked off and texted the pictures to the dealer. He thought I was leaving the box in and said that GM actually calls for more of the liner to be cut when installed with the box. I had told him I was taking the box out as he was there when I moved everything from the old truck into the new truck and everything wouldn't fit under the rear seat with the small box. He said he was going to get me a new floor liner but never did. I didn't push the issue as I have that area covered with the jumper cables bag and had planned to make a plastic filler panel at work. Oh well, can't see it and doubt anything will get on that carpet.
I used to have car seats and boosters in the back seat so I'm also used to just sliding out the stuff I need.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,531 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
