1 hour ago, 2020AT4 said:
I'd definitely change mine for towing mirrors if I was hauling trailers more often.
Yah it’s an expensive upgrade for just looks haha
Definitely! Just looking at the 2020 build options on the GMC website, I think it was a $500 upgrade, or something like that.
Yah on my truck it would have only been $300 I believe, but on a LTZ it requires all of the safety packages, which would have increased my trucks price by $4550.  So I saved a ton of money just adding them my self.
Edited by pewterliftedz
$5k?!?!?! Holy crap!!!!
  • 8 months later...
On 4/24/2020 at 8:04 PM, SamDSJR said:
Yes. I did get them working 100%. I posted in detail on the Facebook Group 2019+ Silverado/Sierra & 2020 HD Trucks. Here's the overview:
Here’s the circuits you have to tap into:
X4 pin 3 - right turn signal
X5 pin 2 - left turn signal
X7 pin 4 - cargo lamp LED’s
X4 pin 13 - running/clearance lamp
PM me and I will send you all the pics and procedures in detail.
    Hi I'm new to this blog. I have a 2020 RST Silverado 3.0 durmax. I forgot to order tow mirrors when I ordered my truck. I basically have manual folding, heated and power from the door with the standard mirrors that came on my truck. I located GM towing mirrors, # 84776100 from "shopchevyparts.com." Seemed to have best price $520 plus shipping to colorado $580.  Looks like they added turn signals, cargo backup to these mirrors, etc. Was told I need to order new wiring harness for the mirrors, which will be another $160.
   Is it necessary to order these parts for both the Drivers and Passenger sides,  (84662371 and 84662372), or can I tap into circuits to avoid these harnesses. Appreciate any input.  Thx,  JB
You need both harnesses. Electrical for 2019 and 2020 is not the same, so I don't believe this thread will help you. You're mirrors aren't available for 2019 trucks because of the electrical system differences.
So question for you guys but in a different direction. My truck came with the tow mirrors and I do not like them. I do not tow enough to ever really use them. I want to move down to the standard mirrors. My current tow mirrors are manual fold, power adjustable, heated and have the task lighting. I have seen the standard size mirrors with the perimeter / task lighting, heated and power adjustable. Only difference is the lights are on the front of the mirror. Can I install them and everything work properly? Hope that makes sense! Thanks in advance for any advice on this!
I too have recently removed tow mirrors from my 2021 GMC Sierra that I would like to sell. Like New Pair of OEM Factory Power Folding, Manual Extending Tow Mirrors. They Have Work LIghts, Cornering Lights, 360 Degree Cameras, Blind Side Alert and Auto Dimming. Like New Condition.
I don’t seem to be able to pm anyone, I’m new to this site and maybe missing something in the settings. Anyway I’d be interested in your mirrors if still available.
thanks
I have been debating on doing the swap to tow mirrors. We just bought a travel trailer to go camping, getting too old to sleep on an air mattress or ground. I have been going back and forth because I know I should get them but I hate the "dumbo ears" look. For now I am going with some snap on extensions since they are the cheapest option right now and I will get them before Memorial Day weekend for our maiden voyage in the trailer.
I was also thinking, once the truck is payed off, that I could somehow retrofit some K2 tow mirror instead. I know there would be body work on the doors besides wiring to get them to fit and work. I feel that they would look better however, just my opinion.
Here is the link to the snap on mirrors if anyone is interested.
https://www.amazon.com/gp/product/B07TM169WF/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I'm interested in buying your power folding tow mirrors. I have a 2021 RST 3.0 with no power folding option. Anyone know whats involved to make these work?
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
