The extra plug in connector servers two purposes - to connect the lighting circuits from the mirror to the factory connect. This will get you blinker on the glass only. That’s the factory function. That’s what you had before. The amber forward shining light behaves as a running light/park light - meaning it comes on when your headlights are on. If you outrun your headlight switch to park lamp mode, that amber would turn but (in a factory state). Your issue is that you’re not setup for tow mirrors. The door harness in your truck is wired different - so there is a path you’ll have to go down to either modify your door harnesses or replace them with a set and … since your truck is as 2014, add additional wiring inside your cabin of your truck that runs into the engine bay/fuse block.
So if you want to get these work, it can be done but will require some additional thinks and effort to get there.
You can reach me at HarnessDR.com for more info. Use the “Contact Us” option there.
Did you physically inspect the brake pads? When my brakes went bad I got a few different messages, one of which was the same as you did, but none of them said, your brakes are bad (or need attention, or anything like that). I actually took it to the dealer because I thought the system was bad. Nope, just some highly worn brake pads.
I used to love working on the old stuff. Mostly Chevys, majority Impalas with a few Novas. Usually for improved performance. Once computers and sensors started showing up I lost interest in working on them. I don’t have the patience. Anyone who can pull it off today has to have patience to do the research and can work in a confined area. Has to really enjoy it. The engine compartment is cramped. I’ve enjoyed the show.
Over the years of having a few in moderation, well almost always. And always fighting my weight Ive tried almost all the brands. Evan Williams takes up the liquor cabinet along side of Fire Ball and blackberry brandy. But in the flavor variety. I’ll admit I love margaritas. But it shows up scale the next day to remind me.
