Aftermarket brake controller
Any one have issues with aftermarket brake controllers? I have a 2019 Sierra where the signal wire from truck isn’t reaching brake controller when pressing brake pedal
Did you use the factory supplied harness that has to be soldered onto the controller plug or did you get a plug and play harness that plugs directly into the truck's socket and the controller?
I installed a Reese unit a year ago and have had no issues. I adjust the brake down when the trailer is empty and back up when loaded. Works great.
