I just did mine install in 1 hour and 20 minutes, that includes running wires from the Switches, into the engine compartment for future use. Two things to help you do this install;
First, insert a long screwdriver into the hole in the rubber boot from the engine side into the cab. Do this for two reasons, one, made sure the path for the new wire is clear and unobstructed, second, while the screwdriver is installed, go into the cab and look were it is located, that way you have a idea were to look for the wire you are going to insert.
Second, spray a little wire lube in the rubber boot to make the wire slide in easier. Make up a 4 wire harness and stick it in the rubber boot after you insert the power wire. You might as well extend the wires from the switches while you have everything apart.
When my truck came in after waiting out the strike I noticed the upfitter switch kit on the back seat. When I asked the salesman about it he said that Was to be installed by the customer. I said well I have a check for $75,000.00 to pick up the truck but you won’t be getting it till the switches are installed. The next day I picked up the truck with the switches installed problem solved.
28 minutes ago, mostcorey95 said:
I was told by my dealer I cant install them due to not having the rpo code 9L7
I figured on something like that as well. I just wanted the hardware and fuses. If I have to, I'll wire them to battery power. I'm probably going to be running most of my accessories through a relay anyway. It'll pretty much be mostly lighting.
On 3/26/2020 at 4:17 PM, blamkin86 said:
First, grab the fuse box, and hold it near where we'll be installing it:
First, the black plug you just put on the red wire from the first steps, plug that into the fuse box. I don't have a picture of this, but there's only one place it can go.
At this point, you're switches are wired into the harness in your truck.
I understand you can change the 5 switches as to where they are used with ignition on / engine running and or engine off and hot at all times controlled by the switch. Someone said by moving the fuse over in the same slot but different connection within the slot. Anyone got the new fuse panel where they can take a photo of the open fuse access?
Chuck
So I  went on a quest to get more info on the famous knee bolster removal and replacement. I know the up fitters #153 has a small pictures to kinda get some info BUT not enough. It was discovered that half the dash must be removed to get to it! It is because of 1 screw under the radio trim. I found a GM link to a PDF file on how to remove the dash trims for replacement of various panels. Here is the link
https://photos.app.goo.gl/d2UVb4djaqf3ashL9
So now this shows where the screws are as well as the push clips.
I used the wrong link. Here is the correct link This is a PDF file.
https://www.gmupfitter.com/files/media/photo/1265/Instrument Panel Knee Bolster Replacement.pdf
Chuck
Edited by Gecko50
Thanks for the write up and the picks... For those of you not lucky enough to have GM at least change out the dash and gave you all the parts here are some photos to help with the process. FYI you have to disassemble a lot of things be prepared. I am also doing this on a 2020 AT4 3500.
1.  Push up on the gauge cover. Just the leather part.
5. Pull both sides away from center council
6. There are two tabs under the arm rest that need to be popped up then you can slide out the cup holder. Use =cation as there are wires attached. I disconnected one of them to be able to move it out of the way.
7. This is probably the worst piece of trim in the world to get off. Its the little piece just under the break controller. It has two wings that go down either side. There is a clip at the end of each wing one on the left side front and right side front and one in the center.
9. At the bottom you will see two screws to remove
10. Pull forward from the bottom to move the whole unit including the radio forward a couple of incest
11. Snaps around the edge will allow the radio to fall forward with the vents
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 395 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
