Anyone found a set that will work with the 2020 Sierra's
I reached out to ZROADS to see if the '19 Silverado model would work on the 20 GMC thinking the hinges/hood might be similar.  They got back to me.  Just curious if anyone else has found hood mounts similar to these available?
Response -
We actually have a 2020 GMC 1500 in our shop for R&D right now and they confirmed Z362181 will not work on the 2020 GMC. They will have new part numbers available for the 2020 GMC in 3-4 weeks and should have all the light applications covered. Please check back in a few weeks and we should have new part numbers loaded on the website.
  • 2 months later...
  • 1 month later...
I recommend reaching out to Baja Designs. They have some A-pillar lights for the T1s through GM Accessories. They might be able to help.
  • 1 month later...
Response -
Here is one for you.
https://zroadz.com/i-23909941-2019-2020-chevrolet-silverado-1500-hood-hinge-led-bracket-to-mount-2-3-inch-led-pod-lights-pn-z362181.html
On 9/15/2020 at 11:07 PM, pewterliftedz said:
I bought these mounts for my previous Sierra and just bought them for my new silverado.  They are built very robust.
https://sdhqoffroad.com/collections/19-current-chevy-gmc-1500-sdhq-built-products/products/19-current-gmc-1500-sdhq-built-a-pillar-light-mounts
I believe these may be your only option without customizing some intended for the Silverado
I said it before and don't think I was heard, but I think you should reach out to Baja Designs to see if they have something. Don't just look at their website. Actually call or email them. See the highlighted portion in the attached pic for a clear explanation why. The pic is from accessories.gmc.com. My search parameters were for a 2020 GMC Sierra. 1b7fc4139aef4d2603dfcd7d1e0f8b6a.jpg
  • 3 weeks later...
I went with the SDHQ mounts. I like that they are positioned out of the way and off to the side.  The mounts are sturdy, but a pain in the ass to install.  I dropped a wrench and a washer down into the wheel well trying to install them.  Also not cheap to have it shipped to Canada.
Edited by CNADN SIERRA
added info
  • 4 months later...
That looks sweet!
Can you please link to the bottom bar as well. Thinking of doing this at some point in the near future.
I have a 19 Sierra 1500 AT4 so hope both those items fit when I decide to do this.
Also, any help on how these are wired by chance?
A. Those zroads don’t put out a lot of light.
B. Mounting lights that close to your hood you are going to get a lot of glare off your hood unless you’re running a very narrow spot.
You’ll be better running a light bar on the front of your truck.
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
