Has anyone found a bed rack/overland rack that they really like? The pickings I'm finding in my online searches seem to be slim for the T1's. Anyone have something they really like?
While we're at it, has anyone found an overland tent set up that they enjoy?
Many of the tracks are weak or waaaaay over priced.  You might be best served by fabricating your own or seeing if a fabrication shop will build you one.  Price will most likely come out close to what you can purchase but would be significantly stronger than what you might find on the web.  I believe softopper has a soft top and tent combination that might fit your needs.
Putco makes a super expensive bed rack..like $1300 or something. Seems crazy from my Toyota days but c'est la vie. Subbed in hope someone knows of cheaper, mid-rise racks for RTT use.
Edited by cseaman
These are the new fad with huge bump in tacomas lately. Have you looked at lead time for 4runner/tacoma parts? Good luck getting anything with 4 months, and i'm sure its worse now.
My point is, all the "best" manufacturers are small shops, demand is through the roof the last few years causing huge price hikes and long leads and they're focused on the small truck market.
I'm going to sub in case someone finds something good.
Thanks, everyone. Appreciate the interest.
I'm wondering if it's better to go for the small, locally built rack in this case. Sounds like there may not be anything of note on the market just yet. Like @cseaman said above, Putco makes one - https://www.putco.com/venture-tec-rack-184000 - but that seems to be the only "brand" option I can find online. And you have to buy mounting plates separately. ?
So I've installed a Diamondback tonneau on the back of my truck and I'm working to install Front Runner rails with load bars on the Diamondback to support a RTT.  This should provide flexibility, as the load bars can be used for other purposes, or simply removed.  Just search for Diamondback and RTT and you should see some Tacoma examples.
The only downside with the Front Runner setup is the load bars (the ones that run side-to-side of the bed) max out at 56" wide.  Ideally, I think I want the load bars to be 62+" wide.  I believe they have racks that are wider and will fit our trucks.
As far as other options. take a look at Nuthouse Industries or KB VooDoo.
Awesome, thanks for the info here!
bump in case anyone knows of a good alternative to some of the newer yakima stuff at about $700
I was looking for this one for my 19 high country. Still waiting on a follow up from the manufacturer to see if they will make it for the silverado.
I still like Yakima. Only way to “nicely” get a rack on top of my tonneau cover. Retrax with the rack.
Now, stage two coming this summer, is a roof top tent on a second set of feet between the two tall towers. I will be able to have the kayaks on the rack plus a roof top tent under. Pretty excited about the camping opportunities with this set up, and still with locking storage in the bed
Yes it’s expensive, but fabbing one out of aluminum would be a pain in the ass.
Been looking at this one for a while now.  My planned setup would be this rack with a revolver x4 tonneau mounted underneath that I can still open.  Looking to be able to mount a fishing rod tube over the cab with it as needed, but want to be able to pull the whole setup off when I don't need it.  Possibly a roof-top tent in the future, though I'm no "overlander"...
They make a bunch of other accessories for the F150(and Taco's, of course?), but unfortunately haven't ventured into GM territory much yet.
Best part, I think the price is quite reasonable @$750
https://rcimetalworks.com/product/18-adjustable-bed-rack/
Edited by MidWestAT4
Adding price
Great find! $750 is much more reasonable than I have been able to find thus far. Thanks!
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
