Replaced my condenser today.
Simple repair:
1. Ensured all R1234yf has leaked out. New gauges purchased  as the high and low pressure ports are different than 134a.
2. Shut off engine/remove negative battery cable.
3. Use 5/16” nut driver to loosen intake plenum and air cleaner.
4. Pull red clip up and depress black clip at airflow sensor connector. Remove zip tie clip from hole in air box, place MAF connector out of the way.
5. Depress 2 pcv retainers and remove crankcase piping from plenum.
6. Gently work the plenum to throttle body intake hose loose. Same thing with the hose at the air box.
7. Remove upper and lower air box/filter.
8. Remove 2 bolts holding radiator in place against the core support.
9. Remove the upper air dam (sits on top of condenser/ radiator). Has 4 clips across the top and 2 on each end.
10. Push radiator toward engine. Remove the caps and clips holding the integrated transmission cooler lines in place.
11. Remove bracket bolt on passenger end of condenser hose. Also remove the hose retaining nut releasing both a/c lines.
12. Release the plastic clips holding the condenser to the radiator.
13. Get another person to hold the radiator toward while you pull the old condenser out.
14. Transfer all air dam pieces to new condenser.
15. Add 2 oz pag oil designed for r1234yf to the condenser
INSTALL IN REVERSE ORDER.
Edited by renickh
Grammar
Everything went back together well. Hooked up my new gauges, pulled a vacuum for 30 min with no leaks, but found a problem. Closed valves installed my new 1/2” LH thread R1234yf can tap and went to hook up my yellow hose to the tap. Nope, yellow hose was RH thread.  I guess the kit accidentally supplied the hose for r134a. An adapter was also supplied, but it was exactly opposite of what was needed. eBay seller should be responding to me soon, but be aware during corona virus next day air options are limited. California heat wave is coming so I guess I am stuck for a few more days.
See attached pics of the tools and materials needed to charge the A/C system.
Edited by renickh
Grammar
8oz cans of R1234yf 4 for $120 with free shipping at refrigerant depot
PAG 100 Specifically for R1234yf $15 Napa Also have PAG 46 for other makes
Can tap readily available at Napa
Gauge set eBay $97 delivered or Napa for $279
Vacuum pump harbor freight
Condenser Oreily for $147 with a lifetime warranty
Received my 1/2” LH acme female to 1/2” acme male adapter. This allowed the yellow charge hose to connect to the R1234yf can tap.
R1234yf constantly freezes the can so it took 1.5 hours to load 4 of the 8 oz cans into the system. You have to stop, shut the can tap valve and wait for the can to heat up.
A/c works perfect again. System low side pressure of 55 matched the chart.
Always remember to vacuum down the system for a minimum 30 minutes and leak test the system. The new Freon is way too expensive to waste.
Great write up, thanks.
Sent from my SM-G965U using Tapatalk
  • 2 years later...
  • 8 months later...
Did it actually take all 32oz of R1234yf? The capacity charts I'm finding online show 16oz R1234yf for a '17 5.3L. Planning to replace my leaking condenser this weekend.
  • 1 year later...
Wow that was a great write up. It has probably helped a lot of people out.
 Can’t believe this isn’t a recall and not just an extension of warranty. I hate gm. Bad lifters, bad torque converters.
but thanks for the write up.
you haven’t replied to the last question from another guy but maybe someone else will know or you will read.
but those cans of refrigerant have oil in them as well?  If so is it the correct amount per can to ensure the correct ratio of oil to refrigerant is applied?  Or is there a separate oil application?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
