service trailer brake system flashing
Terry Barter
Hello.
I have no power output at my trailer outlet plug on my 2012 sierra 1500.
Things I've done  so far: checked ALL fuses, changed the trailer brake control module(at rear of truck)
Can you help me figure out what the problem is ?
Do you just the 12V power? if yes then have you attached the wire wound up by the brake booster to the stud at the front of the fuse box? Also there was a dummy J-case fuse in some of the fuse boxes on these trucks from the factory.
