For years, I’ve been running supertech synthetic and never had issues. Usually run a purolator ONE filter... I wanted to get mobil 1 for the Silverado, thinking it’s the best oil out there but doubting the cost is worth it.
At Walmart, 5qt of M1 is about $23
costco has 10qt of the Kirkland synthetic for $24.99... seems to be a good oil. And I will be doing 5k changes with no towing really.
will this oil work fine for the life of my truck?
I use Mobil 1 0W-20 and a Mobil 1 M1-212A oil filter.  I'm not quibbling over a few dollars on a $50K truck.
  • Like 5
Yeah, on this, I stick to name brands.
I've heard stories of how these "house" brands shop for the best price from suppliers.
I wouldn't buy Kirklands any sooner than I'd buy Amazon Basics oil.
https://pqia.org/kirkland-signature-full-synthetic-sae-5w-30-motor-oil/
There are stories and then there are facts.
Please, read them.
Pretty good oil if used properly on short enough OCI's
Compare the facts to Mobil 1 and you will have a new opinion.
My best guess anyway.
Now for the fun part
Let me get my drink and....
:lurk:
  • Like 5
I switched to AMSOIL XL with the ac Delco filter. Although I have been reading up on Pennzoil Ultra Platinum being really good as well. The only thing I find with the Pennzoil is some of the additive package will settle out on the bottom of the container. I have shaken container vigorously before using on prior changes on my other cars but still seems to not blend. Neither of these oil are Dexos certified. PUP is currently selling for $25 at Walmart and Amazon now.
Mobil 1 Full Synthetic with AcDelco filter changed by the dealer. They change it, rotate my tires and top off my washer fluid for $99. As much as I paid for the truck, I can spare a few bucks for the Mobil 1.
  • Like 4
Whatever the dealer puts in. They rotate my tires and change my oil when the truck says it’s due. Cost wise it’s between $50 and $70 depending on promos. Can’t beat that, especially when you factor in my time to rotate my own tires without a lift. Much rather sit in the lobby and eat free popcorn.
Trigger anyone with that logical behavior yet???
28 minutes ago, steve841 said:
You take your chances, I'll take mine.
Warren Oil isn't exactly small time.
1 hour ago, mookdoc6 said:
Been getting down on the Kirkland 0W-20 Love the price!
TWO five quart jugs for $24!!! There's a price. :)
To each his own.  I'm very shy about letting a dealer or (even worse) a quick lube place touch my vehicles.  Took wife's car into Discount Tire last December for a tire rotation and got 4 cross-threaded lug/lug nuts and one lug with no lug nut on it.  I haven't used my free GM oil change and probably won't.  First oil change was NAPA Synthetic (Valvoline) and I went with the oem AC Delco PF63e filter only because Amazon had them for around $3.99 back earlier in the year.  I usually run Wix or NAPA Gold though.
Edited by Foghorn19
TWO five quart jugs for $24!!! There's a price. [emoji4]
Testing kirkland out in my Kia Optima turbo. Heck why not. Engine has a lifetime warranty for self destructing. Bearing failure. Tried out the AMSOIL engine flush to.
I never let the dealer touch my vehicles unless it's a recall or warranty item.  I had one car come with free lifetime oil changes.  Still wouldn't let the dealer touch it.  I never took GM up on any of their free oil changes.  I've heard too many horror stories about dealers, jiffy lube places and independents screwing up a simple oil change.  I do it myself and it gets done right.  And I know I'm getting the Mobil 1 oil I paid for, the oil filter was installed correctly and the drain plug wasn't tightened with an impact wrench.  Actually, I have Fumoto oil drain valves installed on all my vehicles, which makes oil changes even easier.  And I can change the oil in my garage much faster than I can get it changed at the dealer.
on my trucks I've only used mobil 1 and acdelco filters, change it myself. spending $30 on the oil and filter from Walmart every 7 months or so isn't going to break the bank. acdeldco filter is what came on the truck when I bought it, mobil 1 has dexos, so I went with that. won't change my preference when I get the new truck.
Supertech 0w20 Delco filters from Amazon. Changed at first 1000, then 3000, and now every 5000. 2019 5.3 with 8 speed perfect truck.
Edited by Welder2014
spelling
    • And to top it off finally.......................these small GM LS engines are designed to SPIN!!!!!  Why choke them down to just off idle for cruising.  Why/how the "bean counters" have influenced the "engineering department" at GM is beyond me.   They took a solid platform of an engine and turned into a joke in OEM form!!!
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
