has anyone else had trouble with there truck going sideways on gravel roads in pot holes or washboard ????    is there a fix for this that is not too expensive ????   new here so Thank you for your Time ....
I never had but a friend has. Had to replace shocks. I would look at the Bilsteins.
Sent from my Pixel XL using Tapatalk
Are you are running truck 'unloaded' and have factory tire sizes at the pressures on the door sticker?
If so try running reduced tire pressure - its a free trial.
Washboard road has always been a issue in a pickup -- especially unloaded and at speed.
Suspension adjustment -- by setting tire pressure match current loading -- can help.
I have a 2019 Sierra SLT 4x4, and I lived with the crappy ride for almost a year. I noticed the same thing, it would go sideways when going over bumps, lose rear traction easily, etc. I installed new Bilsteins on the rear about three weeks ago - best $200 I ever spent. The ride is much improved on all less than perfect surfaces.
As others have said, loading up the rear with several hundred pounds and/or reducing tire pressure can help (I tried both) but neither helps nearly as much as getting the junk factory rear shocks out and replacing with good ones.
A LOT of us have this issue. It's very well-known.
Adjust your tire pressures down some, it helps. The shocks will also get better as you put mileage on them.
Best solution, though, is to replace them with either Bilstein (not out yet) or Eibachs.
I just put Bilstein 5100s on the rear of mine today. I haven't driven it yet.
There is now a 5100 for the front but no one has it yet. Part # for the front will be Part Number: 24-293297. The rear is Part Number: 24-293471.
I've driven a truck on washboard dirt roads since before I was legally old enough to do so and every one of them to some extent will do that, and the longer the wheelbase the move pronounced the effect. Trucks are made to haul stuff and when the bed has nothing in it they will tend to get a little "squirrelly", they certainly make shocks that will help but as mentioned a cheap fix it to put something in the bed. Doesnt have to be much...back in my wilder days even a igloo full of ice and beer makes a big difference lol.
I had the same problem on my F150. Bilstein 4600’s fixed it. Can’t wait until they have the 4600’s for the new Sierra. Hate that feeling.
On 7/15/2020 at 7:48 AM, Barry Hartling said:
Thanks Guys for all the help.. going to see if the dealer will help  Thanks again .....
They won't be of any help. You need new shocks to get the more planted ride you're wanting (and should come OEM off the lot!)
The other day I was following Mrs. Econometrics home in her minivan, she was driving my RST. I was watching the rear suspension on my RST... wow... it was just bouncing up and down like a loose noodle. Someone with a TB was driving in front of us, and I honestly didn't see the same play in the rear end. Then a GMT900 1500 CC drive along side my RST for about a mile... same thing. Rear axle just did not look as bouncy. Made me realize how badly I need to get rid of these Rancho twin-tubes.
The key question here is: why weren't you making Mrs. Econometrics drive the minivan?
  • Haha 1
? We had $5500 of (warrantied, thank God!) work done on the suspension, so I needed to make sure the dealer got it right. ?
Which make?
That just sounds more like something that would be happening in the minivan.....
  • Haha 1
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
