has anyone else had trouble with there truck going sideways on gravel roads in pot holes or washboard ????    is there a fix for this that is not too expensive ????   new here so Thank you for your Time ....
I never had but a friend has. Had to replace shocks. I would look at the Bilsteins.
Sent from my Pixel XL using Tapatalk
Are you are running truck 'unloaded' and have factory tire sizes at the pressures on the door sticker?
If so try running reduced tire pressure - its a free trial.
Washboard road has always been a issue in a pickup -- especially unloaded and at speed.
Suspension adjustment -- by setting tire pressure match current loading -- can help.
I have a 2019 Sierra SLT 4x4, and I lived with the crappy ride for almost a year. I noticed the same thing, it would go sideways when going over bumps, lose rear traction easily, etc. I installed new Bilsteins on the rear about three weeks ago - best $200 I ever spent. The ride is much improved on all less than perfect surfaces.
As others have said, loading up the rear with several hundred pounds and/or reducing tire pressure can help (I tried both) but neither helps nearly as much as getting the junk factory rear shocks out and replacing with good ones.
A LOT of us have this issue. It's very well-known.
Adjust your tire pressures down some, it helps. The shocks will also get better as you put mileage on them.
Best solution, though, is to replace them with either Bilstein (not out yet) or Eibachs.
I just put Bilstein 5100s on the rear of mine today. I haven't driven it yet.
There is now a 5100 for the front but no one has it yet. Part # for the front will be Part Number: 24-293297. The rear is Part Number: 24-293471.
I've driven a truck on washboard dirt roads since before I was legally old enough to do so and every one of them to some extent will do that, and the longer the wheelbase the move pronounced the effect. Trucks are made to haul stuff and when the bed has nothing in it they will tend to get a little "squirrelly", they certainly make shocks that will help but as mentioned a cheap fix it to put something in the bed. Doesnt have to be much...back in my wilder days even a igloo full of ice and beer makes a big difference lol.
I had the same problem on my F150. Bilstein 4600’s fixed it. Can’t wait until they have the 4600’s for the new Sierra. Hate that feeling.
On 7/15/2020 at 7:48 AM, Barry Hartling said:
Thanks Guys for all the help.. going to see if the dealer will help  Thanks again .....
They won't be of any help. You need new shocks to get the more planted ride you're wanting (and should come OEM off the lot!)
The other day I was following Mrs. Econometrics home in her minivan, she was driving my RST. I was watching the rear suspension on my RST... wow... it was just bouncing up and down like a loose noodle. Someone with a TB was driving in front of us, and I honestly didn't see the same play in the rear end. Then a GMT900 1500 CC drive along side my RST for about a mile... same thing. Rear axle just did not look as bouncy. Made me realize how badly I need to get rid of these Rancho twin-tubes.
The key question here is: why weren't you making Mrs. Econometrics drive the minivan?
  • Haha 1
? We had $5500 of (warrantied, thank God!) work done on the suspension, so I needed to make sure the dealer got it right. ?
Which make?
That just sounds more like something that would be happening in the minivan.....
  • Haha 1
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
