I just bought a 2018 silverado but my phone (Note 10+) is too wide to fit in to the tray and make contact for charging. Any ideas on a workaround? I just need the tray a little bit wider and I'm set!
I have an iPhone XR, so I’m not quite sure how that equates to yours but here’s what I did. I unscrewed the bezel and dremmeled around the side to make it wider until my phone would drop through. I also had to trim the height of the plastic mat on the bottom so it would sit closer. I had a friend measure everything and he’s going to 3D print me pieces so it looks factory.
Side note, my phone has an otter box case.
I'm in the same boat as you and I don't even have the wireless charging lid on my jump seat. Note 10+ with an Otter Box doesn't fit so I have to just stick it in a cup holder since I haven't found a better mounting solution or cradle for it. Funny how that works though. Never big enough for a flagship phone. Granted, they probably made that area big enough for the biggest phones at the time but should have given more real estate considering every year phones seem to get bigger and bigger...
........ I'm digging this idea. You just got me thinking now. I have a good buddy of mine that has a 3D printer..... Maybe I will do the same thing.
have him do a run. Im sure 90 percent of the people on here would buy one for decent money.
i was curious to see a finished product on having a bigger or wider slot on the lid
I mean I can take a picture of my rough hack job. It doesn’t look the best, but my iPhone XR fits and aways charges. Still waiting for the 3D printed parts from my buddy.
As mentioned, I'm sure if your buddy wants to make some $$ I'd happily buy his 3D console kit if it truly looks factory. I have a Google Pixel 3XL and it's *barely* too wide to fit in the cutout, super annoying. Post pics when you install it!
  • 6 months later...
I just got this in over the weekend, gonna try to install it tonight. I'll let y'all know how it goes.
  • 3 years later...
Did you ever get this printed?
So these are pretty easy to find on eBay:  https://www.ebay.com/itm/317792903215?fits=Make%3AChevrolet&_skw=For+2015-2018+Chevrolet+Silverado+Wireless+Charger+Tray+15W&itmmeta=01KHBXW6JMN15TT4JPS5PFEFQ0&hash=item49fdeee02f:g:B4EAAOSwOB1oHBJb&itmprp=enc%3AAQALAAABIGfYFPkwiKCW4ZNSs2u11xBosOND%2BaIMnRIoNs8WxBNcXvOXRp5E8FApOWKjBDT9v9vIl8N%2FjKZIf3SGxNNK461CEvyMkiCGGniGrf%2FzA5OoYSowhRpn0SH0DfOj8df6Ddyc6N9G7KkHqX3bZ2xYfk0itM%2Bg1XL5bDm1v9LA7B%2BtlSRh97oMpM%2BNlDF8LiCrlh9eKwYZ8n43yfiOx1ucmbMdxR14joDg5Qtq38c92XhnWOU00e4PD00%2BjzwqKQ33Mm6hi31Myy3XE8CvnUO2egtUdVjbyMU8cxyL4%2F44qGmrETojo5%2Bxsmjr1c6wqBqK0sEY8EnWb46Pb2AzXXw6KUKMSB0zv7Puwv4UOIeiGAUnkfitJkTE4OahfHvV412V4A%3D%3D|tkp%3ABFBM_unw_Ypn
Anyone do the upgrade?  Even with the "improved" wireless charger in the 2018, it is absolute trash, and I never use it.  It is too slow and the tray is too narrow for modern, large phones (I rock a S24 Ultra currently).
I'm also curious about this one:  https://www.amazon.com/CZmenghe-Compatible-2015-2018-Replacement-Accessories/dp/B0GLZB7MV2/ref=sr_1_5?crid=2D2H62KEHK0GW&dib=eyJ2IjoiMSJ9.rCjDHNGPtsOkRUUbdH0-4sfHNjikh-OTcqZ2U2Gl3g2LOUzDKVxKv6yPEYPr-e_x0eltka8MA7SrnlNFKAEF569RxBCoGYztErBMO91SxxrzXCdyd2nzR4HKJycb-MxQYctoEvEjZZPuDIVJsr4JFvOFcadq_ucU0invUjozXzIJiPQPiWonozgGFMmzjP0m_HsL0nZhBRdbzhC29JQotfBV-2C7DnVPMqmihJBviWs.oIPCF2YEj9A3MBXa0kz_UytSkjfiQr2AH6YEKg0Nsw4&dib_tag=se&keywords=2018%2Bsilverado%2B15w%2Bwireless%2Bcharger&qid=1771000411&sprefix=2018%2Bsilverado15w%2Bwireless%2Bcharger%2Caps%2C300&sr=8-5&th=1
More expensive but has the magent built-in as well.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,380 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
