Looking to replace my Goodyear Wrangler 265/65R18 tires with something that is more load rated - in the E range.  Like the BFGoodrich All Terrain T/A KO2 Tire but would like to know if a larger size would work on my 18 inch rims.  If I do not lift, is there a max suggestion? Or if I lift 2 inches - is there a better suggestion?  Looking for ideas that will not rub or limit turn radius......  Thanks in advance for all your comments.
I would like to know this as well,  I have the exact same: 2018 Chevy Tahoe Z71 Midnight/Texas Edition.   Did you ever find out what tires you could put on there?
  • 9 months later...
Sorry for the delay - I ordered BFG MUD TERRAIN TA KM3 LT285/65R18 LRE RBL OFF ROAD SPORT TIRE and they look and ride great......
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
