Gutzy Posted July 22, 2020 Posted July 22, 2020 What tool do people recommend for reprogramming the TPMS sensor on there trucks? I do all my tire rotations and in the past I just ignored the sensors and where they were. Is there a reasonable priced tool out there that people recommend and that works good to program the TPMS Sensors?
Jav_eee Posted July 22, 2020 Posted July 22, 2020 Try this one VXDAS Auto Tire Pressure Monitor Sensor TPMS Relearn Reset Activation Tool OEC-T5 for GM Series Vehicle https://www.amazon.com/dp/B072BK693N/ref=cm_sw_r_cp_api_i_wffgFbD7XVCZBSent from my iPhone using Tapatalk Pro
Gutzy Posted July 22, 2020 Author Posted July 22, 2020 11 minutes ago, Jav_eee said: Try this one VXDAS Auto Tire Pressure Monitor Sensor TPMS Relearn Reset Activation Tool OEC-T5 for GM Series Vehicle https://www.amazon.com/dp/B072BK693N/ref=cm_sw_r_cp_api_i_wffgFbD7XVCZB Sent from my iPhone using Tapatalk Pro Has anyone used this one on a 2019 silverado? really doesn't say that it truly works one newer vehicles. definitely looks promising though! Thanks!!
Denny NWO Posted July 22, 2020 Posted July 22, 2020 I use the same one as Jav_eee. It works good and great value for the price.
DiverRick Posted July 22, 2020 Posted July 22, 2020 48 minutes ago, Jav_eee said: Try this one VXDAS Auto Tire Pressure Monitor Sensor TPMS Relearn Reset Activation Tool OEC-T5 for GM Series Vehicle https://www.amazon.com/dp/B072BK693N/ref=cm_sw_r_cp_api_i_wffgFbD7XVCZB Sent from my iPhone using Tapatalk Pro Can anyone confirm if this one works with the GM provided TPMS for trailers? The trailer valves are very different from the ones used on the truck wheels. TIA
AlaskaErik Posted July 22, 2020 Posted July 22, 2020 23 minutes ago, DiverRick said: Can anyone confirm if this one works with the GM provided TPMS for trailers? The trailer valves are very different from the ones used on the truck wheels. TIA There's no reason why it shouldn't. I bought a similar one off of Amazon that works with GM and Ford vehicles and it programmed my trailer TPMS sensors without any issues.
BlancoSilverado Posted July 22, 2020 Posted July 22, 2020 If an Americas tire/ Discount tire is near you, they will Relearn the system for free. ** It might take a few mins for them to do it** - Tech for Americas tire.
USAFRET Posted July 22, 2020 Posted July 22, 2020 1 hour ago, DiverRick said: Can anyone confirm if this one works with the GM provided TPMS for trailers? The trailer valves are very different from the ones used on the truck wheels. TIA This worked just fine on my trailer tires after i had the sensors installed.
DiverRick Posted July 22, 2020 Posted July 22, 2020 21 minutes ago, USAFRET said: This worked just fine on my trailer tires after i had the sensors installed. Thanks! Ordered......
