Never found anything better than Heating and air condition vent tape , the silver aluminum .stuff. I have taped keys under the fenders, hood trim , and had to cut it out with a pocket knife when I sold the truck , or need it. You see I watched My late father hunting in the back woods lock his keys in his sharp 79 chevy PU, and before I could say dad don't, he popped the window. So call me crazy I always have a spare someplace on the truck. Screw technology
I guess this is a bad place to ask a simple question. Forget it guess. I'll figure it out.
I’ll tell you where you can hide a key.
Thanks for the reply badge171.....I feel exactly the same way. It's cheap insurance. FYI, I used that same silver tape on my last truck. The front plate holder on my '96 would allow you to just slide the plate in from the top. No screws holding it in. I just taped a spare key to the back of that plate and slide it in place. Easy peazy! Saved me from breaking a side window one time. Well worth it.
Probably invest in one of these and a alarm that allows u to use a app to open your truck, I personally would never leave a extra set of keys in my truck, shi+ I don’t even like leaving my pistol in it ?
WOW!  That's quite a safe.
It’s a lockerdown safe I bought mine cheap on OfferUp, traded a 5amp DeWalt battery and 60$ for it. It was practically brand new still had the plastic over the buttons... Dude traded his truxk and got a 2019 F250
Don't need this, you just put your keys in the hollow hitch, slide it in the receiver and get a combo receiver bolt lock.  Now it looks just like every other truck with a hitch still in the receiver.
combo lock
That's a dang good idea. Thanks for sharing. It might be a pain if your pulling a trailer, but other than that, it's a great idea.
Sent from my moto g(7) power using Tapatalk
Me too? I just ordered a new comb type hitch pin lock. The spare key has found a home!
DONT..
go to the dealership and have them install the keypad entry. (works like a code-activated keyfob).
I LOVE it on my truck..
32 minutes ago, rbrjr1 said:
DONT..
I've only seen this on FORDs. I didn't know GM offered this. Can you post a picture of yours?
would this be similar to the watch in Pulp Fiction?
Me too[emoji16] I just ordered a new comb type hitch pin lock. The spare key has found a home!
Did you order the one from the link or did you find a different one? I'm thinking seriously about doing that too. I would have never thought of that, great idea.
I ordered it from Amazon with free shipping.  I think it was the same as the one in the link. I actually have a nice hitch cover that the key fits in & it's relatively hidden. The combination hitch pin just adds a level of security (even though it can be picked). I actually found another good hiding place while surfing Youtube but because of the eyes of thief's are here as some have mentioned, I'd have to kill you! ?  the hitch will do for now.
Edited by rav3
On 8/2/2020 at 2:42 PM, ammoaddict said:
It's not that way anymore. I bought my truck in 2018, it only worked for a few months, can't remember how many.
I've been using mine since 2016 and never paid a dime?
They didn't put it exactly where I would have installed it, but i love it.
I haven't looked at the instructions about replacing the battery but it's essentially a code-key fob that sticks to the door with 3M tape.
go to the GM website and search through the available accessories for your vehicle. I dont know if it works with "proximity unlock" setups.. but I dont see why it wouldn't.
Edited by rbrjr1
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
