Hi all,
I just took delivery of my new LT Trail Boss 6.2 last night and I definitely need a tonneau cover. What’s the consensus on a brand that I won’t regret purchasing. I like the looks of the BakFlip MX4, but there are a lot of bad reviews out there. The Chevy tri-fold was another thought, but I can’t really find decent pics of it. I’m open to any and all suggestions, and pics are welcome. Thanks!
6 minutes ago, Darkfader said:
Hi all,
Peragon is a great choice.  Will last as long as the truck does.
https://www.peragon.com/?gclid=CjwKCAjwqML6BRAHEiwAdquMnedr5fYqmdIM4NEj_cV9U3RLjrTFBg_opP4_Pgo7Ex3wbFfHNPhZgRoC4q0QAvD_BwE
Edited by btj_z71
Spelling error
Truxedo Truxport for me. Soft cover that folds all way up. I like the price and value. Paid $309 through AutoAnything. I use my whole bed. The trifold hard cover doesn’t let you use 1/3 of the bed with folded up.  I like them but not for my use
nice purchase. You’ll love the 6.2L.
I've had a few covers over the last couple of years. One reason was my bak roll up failed and had it replaced but got an MX4 instead.
The MX4 has been the best hard cover for sure. Its not that heavy, no mechanism on the box rails like some others that will cut your legs. And it does not interfere with the auto down tail gate and you can close without lifting.
This time I have a truxedo prox as I wantee something to remove in seconds. A lot of covers are in the way for dirt bike bikes.
Sent from my SM-N975W using Tapatalk
I have  had  Truxedo low pros on my last 3 trucks and I love them  , plus I believe a lifetime warranty , I dont like the look of the tri folds myself , but to each his own.
I like the low profile soft roll up covers best for all around use. Most waterproof and secure cover you can get is a Undercover SE  hardtop cover IMO. I liked it for looks and durability, but you were limited in what you can haul in the bed unless you removed the whole cover and left it sitting at the house, but it is painted to match the exact color of truck with a price around 2k.
Tri-folds and hard roll ups are okay, but they do not give you full bed access either, and the good ones are pretty expensive, around 800-1k. Didn't care for the ones I had of them either.
So I've now owned 3 different soft roll ups, and love them. They do leak a little, but the middle of the bed stays really dry, just leaks a little at tailgate and very front of bed. Best part is can use whole bed at any time with ease, and cost is in the $250 range. The last one I bought was from AutoAnything. It is their house brand, which I like better than the brand name covers I've owned before just like it that I paid more for.
Here is the link https://www.autoanything.com/tonneau-covers/autoanything-select-soft-roll-up-tonneau-cover
Nice looking truck. I have the LoMax Access tri fold. Put it on about 6wks ago when I got the truck. Good fit and finish. Tailgate works without interference. Fairly easy install with no drilling required. Took a 700 mile round trip last week and had some rain along the way. Bed was completely dry. $883 at autoanything.com.
Thanks for the suggestions guys. I think I’m between the MX4 and the Lomax. It appears as if the Lomax is easily removed if I needed to, and I’m not sure I even like the way the MX4 stores in the up position if I needed to use the entire bed.
it’s not much difference in price between the two, but I like to buy once cry once. It was really easy to pick out the truck I wanted, not so easy to pick out the bed cover. Lol
I agree, I had the Bakflip Revolver and while it looked nice, caused me nothing but issues, particularly in cold weather.  The plastic clips on the rails would come off or break when you use it alot.  With my new Sierra, I went with the MX4 and have no problems at all, and the auto tailgate comes down just fine.  It's just as sturdy and I think you can even load about 400 lbs on it if necessary?  (never tried or probably will)
I think I'm going to finally pull the trigger on a Pro X15... I like the "lifetime" warranty and also the fact that it will not cover/rest against the back window when open. Anyone with the MultiPro have this and like/unlike the Pro X15?
As I said that's what I have now, bought it for the quick removal when loading dirt bikes or snowmobiles.
Tail gate drops no issues, its not as water tight as mt previous MX4 and a thief can still get in easily but it does what i need
I've carried a 150pound box on mine and had it strapped as best I could to not add extra weight and the cover didn't even flex.
The 400 pounds is distributed weight so don't walk on it haha.
A buddy put down a pc of plywood and carried a heavy couch with no issue
I have that and my high country. Great price and lifetime warranty is perfect.  I also live 40 miles away from Yankton, SD where they are made at.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
